Old 02-24-2010, 04:24 PM   #1
High Iron content question
Hello, first time here. I have well water at my home. I have to replace my hot water tank every 1 -2 years due to the hot water/out fitting rusting out. So far Whites has honored my warranty for 3 tanks. Don't think that will last forever. Plus I am tired of changing out tanks. I was told that I should put a Neutralizer in? Is that what I should use or can I get a whole house filter system (a lot cheaper). Also, should this be piped in before my pressure tank or after? I currently have an old water softner installed that is not running because something is wrong with the resin tank. Can I replace that with either of these systems? Any help would be much appreciated.
Thanks - Brian
baspinall is offline   Reply With Quote
Old 02-24-2010, 04:41 PM   #2
Licensed Master Plumber
You need to run some water tests before anyone can give you a definitive answer.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-24-2010, 04:57 PM   #3
An old Tradesmen
Please do not make duplicate threads. You will get answers as people have either time or desire to give.
I got rid your other thread.
Old 02-24-2010, 06:16 PM   #4
Civil Engineer
Before getting into the question of water quality, check that you have an isolation bushing between the copper piping in your house and the (presumably) galvanized fitting coming out of the hot water tank. The galvanic action between copper and steel will eat up your hot water fitting in a few years unless you properly protect it.
Old 02-24-2010, 07:00 PM   #5
Thanks - I hit the send button and it just hung. So I hit again.
I will get my water tested. I do know it is high in nitrates. When I purchased the home over ten years ago I had an RO system put in.
Brian
Old 02-24-2010, 08:11 PM   #6
Brian
A test high in nitrates is a red flag in my state to do a bacteria test. I would look into that. In Michigan we can get bottles from the health department and just mail them in. The test has to be done at a certified lab.
user69544 is offline   Reply With Quote
Old 02-24-2010, 08:33 PM   #7
Yeah I'll have a lab test it. we do not and never have drank my well water from any tap other than my RO system which is installed in the kitchen tap. Other than my Nitrate issue it seems like the water is seriously high in minerals or something that eats my hot water tanks. Doesn't seem to bother the copper lines as bad.
Brian
Old 02-24-2010, 08:55 PM   #8
High or low PH will eat anode rods, elements, tanks and copper piping.
Negotiating w/Roofer - High Price - need advice Dodah Roofing 11 06-23-2009 08:31 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 06:55 PM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
