Hide Cleanout Plug Behind Drywall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2012, 08:33 PM   #1
Question
Hide cleanout plug behind drywall?
I'm finishing a bedroom in my basement and there is a drain pipe coming down from the kitchen above it. It's got a fitting on it with what looks like a cleanout plug. Unfortunately, it's sticking out, so if I wanted to install drywall, I'd have to cut out a hole and the square piece on the cleanout plug would stick out. I saw that there are low-profile cleanout plugs which would allow me to hide it completely behind a wall. The question is, would this be against code? Is it required to be accessible, so would I have to box it in and put a removable cover on it? Or can I just hide it behind drywall, and maybe protect the pipe behind with some steel?
TomU is offline   Reply With Quote
Old 01-05-2012, 08:35 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why would you want to do that?
That clean out is there for a reason.
XXX
Old 01-05-2012, 08:37 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Clean out has to be accessible. End of story. Put a flush plug in it, and make a nice looking access panel for it, or get a cleanout cover plate.
https://www.google.com/search?hl=en&...fJL8WyiQKS7PAg
Journeyman Plumber
Old 01-05-2012, 08:37 PM   #4
So you would suggest boxing it in and putting a cover over it?
I just don't know how frequently access would be needed. I never ever had to clean out a pipe in any of the homes I have owned. In fact, until now I never knew they were for clean-out purposes, I always assumed it was just a cover for future hook-ups.
Old 01-05-2012, 08:38 PM   #5
Thanks, will do this
Old 01-05-2012, 08:38 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Put your bed or dresser or a stuffed animal in front of it if you can't sleep at night knowing that clean out is in that wall.
XXX
Old 01-05-2012, 08:40 PM   #7
That's not why I wanted to hide/cover it. It just looks ugly as is. I just want a beautiful room.
Old 01-05-2012, 09:03 PM   #8
Rewards Points: 582
tom i have to agree with you... me and the wife went at it about a clean out facing into the great room we both said it looked bad.....however the code dosen't care how it looks....so we took a peice of furniture cut out back to hide c/o plug....happy wife happy life......you will think of something....ben
Old 01-05-2012, 09:30 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 994
I love can't find the clean out calls.. $295.00 later i'll find your clean out.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 2 Users Say Thank You to Javiles For This Useful Post:
ben's plumbing (01-05-2012), Ghostmaker (07-08-2016)
Old 01-05-2012, 11:25 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Take the plug and flip it over.
As long as you know where the clean out plug is im not aware of a code saying it must be accessable,common sense says install an access cover but im not aware of a code off top of my head
plummen is offline   Reply With Quote
Old 01-05-2012, 11:36 PM   #11
Doing it myself
Alan's Avatar
There are access requirements for cleanouts. I don't think you could get it to screw in if you turn it upside down, it should be a tapered thread. Also if it's in a drain stack you wouldn't want the head of the plug protruding into the drain line.
This is why they make flush plugs.
Journeyman Plumber
Old 01-05-2012, 11:40 PM   #12
plummen's Avatar
Depends on what kind of pipe/fitting it is,I flip the pvc plugs upside down sometimes for clearance on outside clean outs.
Old 01-06-2012, 12:13 AM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 562
@ TomU- if you do put in a flush plug with a clean out cover, do not run the anchor screw in further then needed to anchor the cover. If the screw is too long, toilet paper and such will hang up on it and cause a blockage. Then your in deep do-do
FYI, you can get plastic covers that can be textured and painted to match the wall- becomes almost invisible
Old 01-06-2012, 12:18 AM   #14
Doing it myself
Alan's Avatar
The ones that we get bottom out. You have to cut the screw to get it to go in all the way.
Journeyman Plumber
Old 01-06-2012, 12:22 AM   #15
Plumber
Rewards Points: 562
Yep, I've used those too. But most people here shop at the big box places and you never know what the expert in an apron will peddle
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (01-06-2012)
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
