Hi-pitch Ringing Tone - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2011, 10:04 AM   #1
hi-pitch ringing tone
I am getting a hi-pitch ringing tone that goes in and out behind my bedroom wall (almost like a vegas slot machine -- a fading ding ding ding).
Strange thing too is at that it will literally stop for 3-4 days and then come back on all night, going in an out - a fading ding ding ding.
While it was making the noise:
-- I shut off main electricty panel to house, still ringing
-- shut of main water and opened a faucet to drain thinking air, still ringing
-- turned on main sprinkler system, still ringing; as there is a drip system on opposite wall in flower planter outside and i do hear loud shut off valve noise behind wall when they switch to other water areas, I guess
Any other thoughts/suggestions?
Cohiba is offline   Reply With Quote
Old 05-06-2011, 05:19 PM   #2
Rewards Points: 1,548
What is on the other side of the wall? Do you live in a multi-family building or apartment house where the other side of the wall is someone else's home?
Old 05-06-2011, 05:44 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
is it possible that someone doing lawn maintenance lost a watch outside of your room.
mustangmike3789 is offline   Reply With Quote
Old 05-06-2011, 05:53 PM   #4
nothing on other side, small flower bed with sprinkler drip...but on the outside
Old 05-06-2011, 09:46 PM   #5
Could be aluminum siding or gutters or something similar that's expanding/contracting as the temperature changes. Or it could be heating pipes or ducts, also reacting to temperature change.
Or maybe some mice have opened a casino inside your wall, although this seems unlikely.
Pistol Pete is offline   Reply With Quote
Old 05-07-2011, 08:44 AM   #6
Rewards Points: 150
Is there a toilet close, could be the flush valve is leaking or the tank flapper is leaking causing the valve to run.
josall is offline   Reply With Quote
hi-pitch ringing tone Cohiba General DIY Discussions 45 05-16-2011 09:12 AM
Paint for jambs to seal the pitch in ? scarrylarry Painting 7 06-11-2010 03:48 AM
Roofing MINIMUM pitch? ControlTech Roofing/Siding 1 11-26-2009 09:10 AM
best for low pitch roofs tomseeley Roofing/Siding 3 06-09-2009 09:54 AM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 12:16 AM
