Hey Plumbers- Do You Like Double Cleanouts? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2013, 06:27 PM   #1
Rewards Points: 31
Hey Plumbers- Do you like double cleanouts?
For cleanouts outside foundation wall...
I hear it is tough to guide the snake in the proper direction.
Would a wye or combo that just allows downstream snaking be preferable?
I guess you COULD snake the toilet for clogs upstream of the cleanout.
Or some other fitting?
Queso Bandit is offline   Reply With Quote
Old 02-08-2013, 06:53 PM   #2
MarginallyQualified
Rewards Points: 2,464
Where did you hear this?
What did they say the problem was?
Have you ever seen septic line piping in a trench?
Old 02-08-2013, 06:59 PM   #3
Rewards Points: 31
The concern is that it will be difficult to direct the snake in the desired direction of a clogged line (full of water).
So you say no problem with this fitting?
I'm considering 2 cleanouts (one for upstream, one downstream) but it seems overkill and kind of an eyesore.
Yes. I've seen sewer pipe and trench. ?????????
Old 02-08-2013, 07:01 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Combo's for clean outs is against code except for the city clean out. for the home you'll need to have a 2 way clean out, codes may vary. and as for the snake going in the wrong direction that would fall under experience.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-08-2013, 07:05 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 684
You're spot on about codes varying. We can only use combos or approved 2-way clean outs.
Old 02-08-2013, 07:26 PM   #6
MarginallyQualified
Did they not have a clean out/vent pipe on them?
How was that pipe oriented relative to the waste flow?
Old 02-08-2013, 08:09 PM   #7
Rewards Points: 31
I'm replacing and realigning the existing cast iron with ABS.
I was planning to use a wye or combo like your drawing but with a vertical riser.
Then I discovered the double clean out so the upstream direction could be snaked too.
I heard or read that these fittings are a PITA to snake cause its hard to guide the snake the desired direction. The question is whether I should use a double clean out.
Just curious, why would a combo with vertical riser be against code for a clean out outside the building?
Old 02-08-2013, 08:42 PM   #8
747
registered
747's Avatar
Rewards Points: 534
Now this kind would be a problem getting it to go opposite direction. But mine is straight up in the yard. No problem going either direction I thought they only used this kind above in a basement or crawlspace.
747 is offline   Reply With Quote
Old 02-08-2013, 08:53 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How deep is the line? If you're terribly deep, i can see how it might be difficult to send it the way you want it.
I just ran a snake up a 2 way cleanout that was about 2ft below grade without any problems.
Granted, once you're in the line, you're ONLY snaking the mainline. Any branches that are clogged individually are not accessible from the 2 way.
Journeyman Plumber
Old 02-08-2013, 08:53 PM   #10
MarginallyQualified
I've seen some change and straighten up (like for a deep trench in a short front yard)... but I've never seen any where the first fitting at the bottom isn't made with that wye/45.
Old 02-08-2013, 11:17 PM   #11
Rewards Points: 31
Thanks for all the replys
I'm only about 2 ft deep so it is sounding like its a non issue.
No existing clean out so anything is an improvement!
Old 02-09-2013, 10:22 AM   #12
Doing it myself
Alan's Avatar
I just want to add : One thing that I DO like about a 2 way cleanout as opposed to a wye/45 is that once you think you've got the clog busted loose, you can physically see the water flowing through the pipe. Whether it's used for snaking or not, it serves as a good inspection point.
Journeyman Plumber
Double switch and single switch in same box? Mallard1123 Electrical 2 09-19-2012 11:06 AM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 12:44 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 04:52 PM
