#1 |
Help! Yellow Hot Water
My hot water has a yellow tint to it at every place in my house. It stays yellow even after it cools to room temperature. The cold water is crystal clear at every location. At first I thought it might be the hot water heater, so I replaced it yesterday. Now I am not so sure. I ran the water continuously for over 1 hour today and no change.
I have copper pipes out the the hot water heater and under my sinks, so I am assuming all the lines are copper. Any ideas??? |
#2 |
Average Joe/ex-Navy IC3
Well or City water?
Brown, Red, Orange or Yellow Water Brown, red, orange, or yellow water is usually caused by rust. The different colors can be attributed to varying chemical oxidation states of the iron (rust) and by varying concentrations of the rust in the water. There are two major sources that can cause water to be rusty:
The other major cause of brown, red, orange or yellow water is rusty water pipes in your building. If old, rusty pipes are discoloring your water, consult a licensed of plumbing materials or an experienced plumber. Water that is being discolored by rusty pipes is not a health hazard; however, it is an indication that the pipes are corroding and they can eventually leak. The first step in solving a brown or yellow water problem is to distinguish if the problem is located in your building or if it is in your city or town water supply. The following are some common characteristics of a water main disturbance:
Another possible cause of brown (or black) water is manganese, the presence of which can also be confirmed through analysis. http://www.mass.gov/dep/water/drinking/color.htm#color
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Display Modes | |
| back flushing a water line. | woodywoodwick | Plumbing | 5 | 10-18-2012 05:10 PM |
| Water heater solutions to get hot water in timely manner | daluu | Plumbing | 22 | 05-07-2012 09:44 PM |
| Oil fired furnace and hot water heater question | steveinpa | Plumbing | 3 | 08-10-2010 09:42 AM |
| water borehole question | joeuser | General Discussion | 2 | 04-18-2010 11:33 PM |
| Low Hot Water Pressure | btennant | Plumbing | 4 | 12-09-2008 10:31 PM |
