Old 10-31-2012, 04:44 PM   #1
Help with what parts I need to fix tank problems
Hi Guys,
I'm awful with plumbing, but I was wondering if you guys could point me to the right parts that I need. I don't think my simple problem is worth hiring someone so I thought I'd ask you guys:
The plastic piece disconnected from the flange that opens and can't reconnect so I need that part replaced.
The lugs that bolt the toilet down are rusty and that rust is getting the bowl nasty. So I could use some help with which they are and what/where I should order those too.
The pipes in this toilet are straight up nasty too, maybe I should change them? I could try to clean them.
Thanks for your time!
Drywallhelp is offline   Reply With Quote
Old 10-31-2012, 04:54 PM   #2
Experienced
Jackofall1's Avatar
Just replace the flush lever, the piece that came disconnected, take it out and over to a local hardware store they will set you up just fine. As for the rusty bolts, I wouldn't worry about them.
Mark
Old 10-31-2012, 05:40 PM   #3
Looks like the piece on the flapper where the chain connects just broke off.
Replace the flapper.
About a 5 min. fix.
The other stuff does not matter.
http://www.fluidmaster.com/our-produ...t-flapper.html
Old 11-01-2012, 10:58 AM   #4
Thanks!
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 7 03-06-2013 07:40 AM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-28-2011 12:30 AM
hot water tank help needed psp Plumbing 2 08-22-2010 03:46 PM
Fish tank plumbing problems.. Raibaru Plumbing 2 12-15-2009 03:13 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
