-   -   Help with what parts I need to fix tank problems (http://www.diychatroom.com/f7/help-what-parts-i-need-fix-tank-problems-161752/)
Drywallhelp 10-31-2012 03:44 PM
1 Attachment(s)
Hi Guys,
I'm awful with plumbing, but I was wondering if you guys could point me to the right parts that I need. I don't think my simple problem is worth hiring someone so I thought I'd ask you guys:
The plastic piece disconnected from the flange that opens and can't reconnect so I need that part replaced.
The lugs that bolt the toilet down are rusty and that rust is getting the bowl nasty. So I could use some help with which they are and what/where I should order those too.
The pipes in this toilet are straight up nasty too, maybe I should change them? I could try to clean them.
Thanks for your time!
:jester:
Jackofall1 10-31-2012 03:54 PM
Just replace the flush lever, the piece that came disconnected, take it out and over to a local hardware store they will set you up just fine. As for the rusty bolts, I wouldn't worry about them.
Mark
joecaption 10-31-2012 04:40 PM
Looks like the piece on the flapper where the chain connects just broke off.
Replace the flapper.
About a 5 min. fix.
The other stuff does not matter.
http://www.fluidmaster.com/our-produ...t-flapper.html
Drywallhelp 11-01-2012 09:58 AM
Thanks!
