HELP !well Water Cover Busted By Truck - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2010, 07:28 PM   #31
Licensed Master Plumber
Wow, a week and 49 posts for a half hour repair, not bad.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 04-24-2010, 09:43 AM   #32
A week & now only 34 posts
Right decision wasn't made....so I made the decision
Old 05-01-2010, 06:48 AM   #33
Hey guys, I have observed all comments and thank you most sincerely for taking the time to help me out. To date I have not fixed it as there appears to be no contamination via the well, but as soon as I get 1/2 hour NHMaster
I will fix it.
Thanks to all- David
iamapratt is offline   Reply With Quote
Old 05-01-2010, 11:54 AM   #34
Rewards Points: 1,910
David, that needs to be fixed asap. Just because they were deleted doesn't mean Driller 1's concerns weren't valid.
Old 05-01-2010, 12:42 PM   #35
I've got it covered with a bucket
Old 05-02-2010, 06:48 PM   #36
Just make sure that between now and the when you get it fixed, you don't drink the water and be sure to properly chlorinate the well when you button it back up.
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
