Help! Wax Ring/closet Ring - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2011, 11:30 PM   #1
Rewards Points: 27
Help! wax ring/closet ring
Hello everybody!
Recently my toilet upstairs start leaking. I decide to replace wax ring, but as you can see on the picture, metal flange is not in the good shape. Should I replace metal flange as well, or not? If so, how difficult it is? Does metal flange attached only to studs, or to PVC pipe as well?
Thanks a lot for help.
Help! wax ring/closet ring-2011-12-14-19.23.22.jpg   Help! wax ring/closet ring-2011-12-14-19.23.47.jpg   Help! wax ring/closet ring-2011-12-14-19.24.02.jpg
Mikhail is offline   Reply With Quote
Old 12-14-2011, 11:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't see a problem with any of it. It's just ugly and sticky.
Just pry the old funnel and ring out of there (if it is still there) and replace it with a new one. Use the one with the funnel built into it. Also be sure to buy the thicker/taller seal.
I think "Kant Leak" (or something like that) is a common one you can find almost everywhere.
XXX
Old 12-14-2011, 11:56 PM   #3
DIY staff
Rewards Points: 7,174
That still looks useable--however,if the ring is to rusty to hold a toilet bolt securely--you can get a flange repair ring--it's a thin flat steel ring with 'ears' for the screws---that goes over the top of the rusty one and simply screws to the floor---
Old 12-14-2011, 11:59 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now that I look at it closer it looks as if one of the slots is damaged. How about cleaning it up a little and providing one more photo. Remove everything (goop and paper wise) that you can so we can see what's really there.
XXX
Old 12-15-2011, 12:18 AM   #5
Rewards Points: 27
Yeah, one slot looks "open", slightly bended at the "entrance" . Someone put to much force on it. Anything I can do about it?
Old 12-15-2011, 12:23 AM   #6
Rewards Points: 27
also I just notice that flange has 4 holes for bolting to the studs, but only 2 screws. That probably not good as well, or two screws is good enough?
Old 12-15-2011, 01:02 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
Like Mike said- get one of these. A good hardware store will carry it. Put 4 screws in the new holes
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-28-2016 12:52 AM
closet ring flange help/explaination eyeglass Plumbing 2 09-09-2009 07:35 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Ring Main Question Andyjr Electrical 5 09-14-2008 10:47 PM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
