Help! Water Heater Pilot Light - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2012, 07:59 AM   #1
Hi Everyone, I'm at my witts end with my water heater. I have Bradford White Model: MI5036FCX2 gas water heater. The pilot light constantly goes out. I have replaced the thermostat and thermocouple. There is a little button/switch that has to be reset everytime the pilot light goes. Could the button be the problem? Right now the only thing I can figure out is since it is in my attic, the summers down here in south east texas are just too hot for it? It seems that this only happens in the summer. Its gotten to the point that I have to relight it every morning so my family can take showers. Please help.
chris77535 is offline   Reply With Quote
Old 06-18-2012, 09:06 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by chris77535 View Post
The pilot light constantly goes out. I have replaced the thermostat and thermocouple.... Please help.
As the WH seems to have no trouble re-lighting and staying on in *some* circumstances I'll suggest that you look outside of the heater itself for a cause.
The most obvious thing is outside air coming down the flue pipe.
If it doesn't have a cap... this $10 fix might just do it.
hth
Old 06-18-2012, 08:10 PM   #3
Hi HTH, thank you for the advise. When I got home tonight I looked at the vent and it looks like everything is ok.
Old 06-18-2012, 08:20 PM   #4
Here is a picture (If i uploaded right)
Old 06-18-2012, 09:09 PM   #5
MarginallyQualified
So much for the cheap & easy fix... huh?
Well, I'm sticking with the notion that something external to the WH and it's controls is making the pilot go/blow out rather than it just doing so all on it's own (after having been on all day long with no problems).
Look around for something that is changing the air flow in the area.
Is there an attic exhaust fan that comes on? Something...
Old 06-19-2012, 01:06 AM   #6
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
possibly due to an over heating condition. The overheating condition must be determined prior to putting the heater back in service.
1. Verify adequate combustion air supply is available.
2. Clear jacket slot openings of any dirt, dust, restrictions or other obstructions.
3. Inspect flame arrestor plate and clean with stiff brush and/or vacuum to remove scale deposits and debris.
PROBABLE CAUSE
Insufficient
combustion Air
1. Weak switch or
switch out of
calibration.
2. Incorrect switch.
Flammable vapor
incident
Color Code
Blue 240 degrees
Yellow 270
Red 290 also water heater vent installed up side down /wrong direction
wctekkk is offline   Reply With Quote
Tags
pilot light , water heater , water heater pilot light
I can light the pilot, but....(water heater) linnea Plumbing 12 12-29-2014 04:07 PM
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 02:55 AM
Gas water heater - after long use pilot goes out. paulsaindon Plumbing 1 07-14-2011 04:51 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
