Help With Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2009, 09:55 AM   #1
Help with Water Heater
Hi, we just moved into a new construction home. There is a SuperStor SSU-60 water heater in our basement. the problem is, the water in the house doesn't get hot at all. it's warm at best. can someone please explain how to increase the water temperature? we've looked all over the web and in the manual but it doesnt help. There are no switches, knobs, or anything that can we even use to adjust on the actual tank. thanks!
jess119 is offline   Reply With Quote
Old 03-09-2009, 11:28 AM   #2
Rewards Points: 1,494
Any access panels that can be unscrewed? Electric water heaters have screwdriver adjustment temperature controls under each of the two panels on the side.
Is yours a "full heater" or just a tank? Some Superstor models rely on an external heater or furnace to actually heat the (domestic) water or to circulate boiler water through a coil in the tank. A furnace may need a separate motorized zone to make all of this work properly.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
