Help, Washer Overflowing Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2011, 04:14 PM   #1
help, washer overflowing drain
my washing maching is in my basement its drain line sits in a 2 in pvc pipe about 4 feet off the floor this pipe connects to the main waste wate line going out of my house (the pvc pipe comes directly off of the main line and is only 5 feet or so long) prob is every time i run the washers the pvc pipe backs up and overflows the pvc pipe is completely clear and i have snaked the main line i dont know what the problem is
Jesse40583 is offline   Reply With Quote
Old 05-28-2011, 04:31 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
sounds partially clogged to me. how far down the main drain line were you able to snake. how long has this been happening. do you anything else that is draining slow.
mustangmike3789 is offline   Reply With Quote
Tags
washing maching
washer drain line jbarkley Plumbing 2 05-07-2011 09:52 PM
Washer drain pipe hehowerton Plumbing 2 04-25-2011 09:28 PM
Washer Drain into Sewer Line near Clean-Out brmatthews Plumbing 4 12-16-2010 01:53 PM
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
