Help With This Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2013, 04:00 PM   #1
Rewards Points: 240
help with this valve.
here is my shower valve. the problem, the water does not come out hot enough.
there is a limiter inside there. i can muscle the handle a little and get it a little hotter.
i need to get this apart. but its stuck. i took the handle off easy. but thats it. i don't care how it comes apart, except that the valve itself is still working. as i don't want to replace it just yet.
Fix'n it is offline   Reply With Quote
Old 11-29-2013, 05:39 PM   #2
Rewards Points: 582
front cap should pop off to access handle screw and limit adjustment...ben sr
Old 11-30-2013, 10:24 AM   #3
Rewards Points: 240
yeah, thats what i figure/d. but it didn't want to come off. i will try harder.
Old 11-30-2013, 07:21 PM   #4
Rewards Points: 240
i got it. there is a set screw under the handle. then that whole piece comes off, with some effort. all is good for a warm shower now
Old 11-30-2013, 07:28 PM   #5
Rewards Points: 3,130
Really irks me that the nanny state thinks it needs to protect us from hot water and from ourselves. I'm sure faucets cost more because of the added parts. And my tankless water heater came pre-programmed for only 120 degrees. Good thing that was easy to change.
The Following User Says Thank You to md2lgyk For This Useful Post:
Arlo (12-01-2013)
Old 11-30-2013, 11:13 PM   #6
747
registered
747's Avatar
Rewards Points: 534
I bet if you Hit it with some CLR a couple times and walk away. It will bring back the shine. Just dilute a little in a spray bottle. Not like the instruction say.
747 is offline   Reply With Quote
Old 12-01-2013, 08:23 AM   #7
Rewards Points: 240
its actually a nice safety feature. slow reacting persons could bump the handle. and get burned because they couldn't turn it back fast enough. had i thought about it at the time, i would have just turned is back a little, instead of cutting it off.
Old 12-01-2013, 08:26 AM   #8
Rewards Points: 240
yeah, its a bit dirty, ay. the whole bathroom is going to be gutted someday. so i am not much interested in spotlessness in this room.
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
