Old 06-06-2010, 04:54 PM   #1
erb
Exclamation
help turning on gas
http://wtfisgmail.com/stuff/dsc06939.jpg
The gas line comes in from the bottom
there is a valve
then there is a saucer like attachment - what is that?
there is another valve before the meter
(valves open on water heater)
I turned the rectangle valves near the meter every which way but I get nothing - Which leads me to my next question which way closes the valve? Right? I confuse myself thinking it's backwards.
I'm under the impression the gas is on from the street. I suppose I should double check that.
Thanks!
erb is offline   Reply With Quote
Old 06-06-2010, 05:57 PM   #2
Super Moderator
help turning on gas
Remember this--in line is ON.
The bottom valve is 'in line' so it is on. The disk like thing is a presure regulator. The upper valve I can not see well enough to know if it is 'In line' with the pipe or not.
Good luck--Mike--
Old 06-06-2010, 07:19 PM   #3
help turning on gas
How, why and when did the gas get turned off? If you acquired this property and the gas was already off it may be that the gas company has the gas turned off. Maybe it was shut off by the gas company when previous owner didn't pay bills or maybe they felt the gas lines/appliances were unsafe.
I'm on propane and if I need the gas turned off for some reason the propane company wants to be the one who turns it back on and fires up the furnace for the first time. Your natural gas company might have similar requirements. Have you talked to them?
Old 06-06-2010, 07:51 PM   #4
erb
help turning on gas
I'll be calling tomorrow morning.
Old 06-07-2010, 09:06 AM   #5
help turning on gas
There should be a valve in the street on your line after it tee's off the street main. Look for a cover plate labled "Gas Valve" somewhere outside along the curb line.
The Engineer is offline   Reply With Quote
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 06:00 PM
Totaline P286-1600 turning on when it shouldn't CSILogan HVAC 1 12-15-2009 05:15 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
