Help: Toilet Venting And Critical Distance - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2009, 11:55 AM   #1
Help: Toilet venting and critical distance
Hi, first time poster here.
I have a basement toilet that is within 4ft and connected to the main stack. It does not have an additional vent. It was this way when I purchased the house and seems to work fine for the few times we have used it. We are in the process of completing this basement bathroom but I really don't want to bust up the concrete floor. Could someone please explain "Critical distance" and if it applies for my situation as well as the ramifications if I left the toilet connection as is?
Nwl_one is offline   Reply With Quote
Old 07-14-2009, 12:16 PM   #2
Remodeling Contractor
you will be fine. The size of the toilet line allows (in many locals) the venting to be a wet vent.
Old 07-16-2009, 10:53 AM   #3
Thanks.
So what is critical distance? When and where does it come into play?
Old 07-17-2009, 02:20 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
A toilet has a built-in trap and has to be within a "critical distance" from the stack based on the size of the closet bend line. Local code from your Building Inspection Department can tell you what it is in your jurisdiction.
The 4' should be fine everywhere I would think.
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-17-2009, 02:27 PM   #5
RippySkippy's Avatar
Our local code allows toilet for toilets to be vented up to 6' away.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
