HELP!! Toilet Leaking From Sides Of Tank When Flushed. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2011, 08:30 AM   #1
HELP!! Toilet leaking from sides of tank when flushed.
Hi All,
Sorry if this has already been answered, but I did some searching and couldnt seem to find my exact problem.
I tried to replace the wax seal on my upstairs toilet yetsterday. Overall the job went pretty well, minus the fact that I tried to be a hero and move the toilet by myself, and set it in the tub upside down so it could drain out and I could clean off the old wax.
Upon doing so, I took a break by resting it on the tank (so the bowl was pointing skywards, like a chair that tipped backwards. The water connector line from the water supply to the bottom of the tank broke off, so I ran to home depot and got another one, easy fix.
BUT, upon getting the toilet back on and the water line attached, the toilet now leaks a considerable amount (maybe 2 cups) upon flushing. No leak when the tank is filling. I am thinking I broke something on the inside when I set it on its tank, given that it must have dropped an inch or so once that water line broke off. Is this fixable or did I ruin the whole toilet? It is a two piece.
Thanks in advance, realllly cant afford a plumber right now lol. As usual, you guys are awesome!
teamcampreder is offline   Reply With Quote
Old 07-30-2011, 08:38 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Take the tank off the bowl. There should be a doughnut shaped seal between the two. Replace with new. Careful when you tighten it back up that you dont break the flanges off the bowl.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
teamcampreder (07-30-2011)
Old 07-30-2011, 08:42 AM   #3
Thanks a bunch! To take the tank off the bowl, I have noticed that their are two plastic screws in the bottom of the tank with a nut holding everything together from the bottom. When trying to unscrew these I nearly stripped them after one try. Would it be worth it to replace these with something more robust while I do this?
Old 07-30-2011, 08:42 AM   #4
the Musigician
DangerMouse's Avatar
Where exactly is it leaking from? If between tank and bowl, do as 12 penny says. If on floor, you did not set wax ring correctly.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 07-30-2011, 08:48 AM   #5
DIY staff
Rewards Points: 7,174
And if leaking from the tank lid--the little hose simply came out of the over flow tube.
Old 07-30-2011, 08:52 AM   #6
It is leaking from where the tank meets the bowl.
Any thoughts on using better hardware when I attach the tank back to the bowl? It is going to be a bear to get off and I would rather avoid that in the future
Old 07-30-2011, 08:58 AM   #7
DIY staff
Typically the tank rebuild kit comes with new seal--and tank bolts and washers.
Old 07-30-2011, 09:02 AM   #8
the Musigician
Be sure to take model # and brand name info with you. There ARE different sealing foam rings for different brands. Also different for pressurized/not pressurized tanks too.
(don't ask me how I found THAT out! )
DM
Old 07-30-2011, 09:06 AM   #9
DM
Would bringing the broken seal with me to HD help determine that? I don't see a model number, just that its an American Standard and then the LPF/GPF rate. Its a basic toilet, I do know that.
Ahh homeownership
Old 07-30-2011, 09:10 AM   #10
Rewards Points: 1,448
Replace the screws.
If you chew up a screw when removing it, even just a little, do not re-use it. Throw it out immediately.
Otherwise if there is a next time then you might not be able to get the screw out.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 07-30-2011, 09:40 AM   #11
the Musigician
Couldn't hoit! woowoowoowoo!
DM
Old 07-30-2011, 06:58 PM   #12
So.... got home after a ten hour workday... ready to attack the toilet, and when I flushed it to drain it out... no leak!! I am obviously going to test it out more, but if no water shows up, should I still take the whole thing apart? Could the water be leaking into the subfloor now instead? I dont really see how that is possible because their is literally no moisture on the outside of the bowl, but I am paranoid. Things like this never happen to me, I am Mr. Murphy'slaw
Old 07-30-2011, 07:18 PM   #13
DIY staff
Make sure the bolts are tight between the tank and bowl---Could be the tank was out of position a bit due to loose bolts.
Old 07-31-2011, 09:32 AM   #14
So I wok up this morning, and their was now some water coming between the tank and the bowl, via the screw that holds the two together. After further inspection, I now see that the toilet has developed a small crack which is leaking a few drops of water around the screw. Does this mean new toilet?
Old 07-31-2011, 09:49 AM   #15
the Musigician
I would dare say yes.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
oh'mike (07-31-2011), teamcampreder (08-01-2011)
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 10:21 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Carbon particles in toilet tank BobMac Plumbing 0 11-21-2010 02:58 PM
Leaking tank DCPete27 Plumbing 7 06-04-2007 10:39 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
