Help With Toilet Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2013, 08:04 AM   #1
Rewards Points: 171
help with toilet leak
So i was gifted a toilet that was barely used.
I finished installing it yesterday and realized it was leaking water from the tank....
steps i took:
added new gaskets to the top and bottom of the screw that connects the tank to the toilet and put in some plumbers putty between the top gasket and bottom of tank. i also used plumbers tape on the bottom part of the screw where it was screwed together.
i also took off the large rubber gasket where the water flows into the the toilet from the tank and added in some plumbers putty there.
end result...the connecting screws no longer leak (old gaskets looked dry rotted)
but i still noticed a dabble of water coming from where the tank flushes water into toilet.
what are some suggestions on how to fix this?
rygar is offline   Reply With Quote
Old 05-06-2013, 08:07 AM   #2
Rewards Points: 12
I've had this issue before and the only thing that worked for me was to purchase a new rubber gasket that goes between the tank and bowl.....the rubber gasket was pinched in shipment and I didn't want to hear the ping from over-tightening the screws.
rkingndayton is offline   Reply With Quote
Old 05-06-2013, 08:10 AM   #3
did you change the flapper?
Old 05-06-2013, 08:17 AM   #4
Rewards Points: 171
still have the original flapper.
Old 05-06-2013, 09:05 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like you bandaided the tank to bowl gasket with plumber's putty. I bet it's leaking there.
Get a new tank to bowl gasket.
Journeyman Plumber
Toilet (Mansfield) Ghost Leak golddog Plumbing 6 10-25-2012 07:10 PM
toilet leak julay Plumbing 2 09-06-2012 12:58 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Wax Ring Replacment and Toilet Leak kennykenny Plumbing 4 11-27-2010 02:43 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
