Help With Soil Stack Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2009, 09:38 PM   #1
Help with soil stack leak
I have water wicking up from the joint where the main ABS drain goes into the cleanout fitting and then into the concrete floor. I have tried to use the standard ABS cleaner and glue, but it seems to always dry with pinholes where the moisture is coming up. With flushing toilets and dishwasher etc., it really leaks a lot. What is the proper way to correct this situation ?
tmbrink is offline   Reply With Quote
Old 03-08-2009, 10:10 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Is the clean out fitting ABS?
Old 03-08-2009, 10:30 PM   #3
Yes, Black 3" ABS into a Black Cleanout fitting.
Old 03-08-2009, 10:35 PM   #4
I should have said both pipe and fitting are ABS>
Old 03-08-2009, 10:41 PM   #5
Rewards Points: 560
I would get a new clean out and 12" of pipe and 2 ferncos.
Cut the pipe into (2) 6" pieces and glue them into the new clean out. Cut the stack the same lenght as the new piece that you just made up and use the ferncos to tie in the new piece.
Old 03-08-2009, 11:01 PM   #6
Unfortunately, the cleanout lower piece is buried in the cement. The cleanout plug is at the level of the concrete.
Old 03-08-2009, 11:05 PM   #7
Rewards Points: 560
post a pic please
Old 03-08-2009, 11:23 PM   #8
I don't have that capability, Sorry.
Old 03-08-2009, 11:26 PM   #9
Rewards Points: 560
I would say that it is time to sart busting concrete.
I would say have a plumber come by and look at it and give you the idea on how to repair it.
Old 03-08-2009, 11:38 PM   #10
Isn't there a way to bond the less than 1/32 " crack. Possibly Silicone Sealant ? I hate to spend hundreds of dollars for such a small leak.
Old 03-08-2009, 11:44 PM   #11
Rewards Points: 560
Sure there are some ways to fix a small leak but to me as a plumber there is no leak that is to small when it comes to waste and feces leaking into a space.
Call a pro and see what they advise
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 04:23 PM
Vent stack leak and install question bjstewa Plumbing 5 06-09-2007 10:01 PM
Soil stack "cover"? DIYGmaLynn Plumbing 3 09-04-2006 01:23 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
