Help With Small Leak On Cold Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2008, 06:11 AM   #1
Help with small leak on cold water tank
I have just had my cold water tank in the loft replaced with a new plastic one. About three days after it was fitted a small drip appeared on the pipe that supplies the bath room. Its on the screw join, in the thread between the tank and the pipe.
I called the engineer out and he told me it was nothing to worry about and would fix its self. A week later and the drip is back, the water not the engineer.
I check it every day so it is a very slow leak that amounts to a couple of drips a week. Is this a problem ?
Fronken is offline   Reply With Quote
Old 10-17-2008, 08:54 AM   #2
Registered User
Termite's Avatar
Well, it certainly isn't going to fix itself.
I'd suggest calling whoever installed it and getting them back out there to take that fitting apart, re-seal it, and reassemble it. Do not accept the repair if they smear pipe dope or some other sealant on the outside of the threaded connection without taking it apart...It needs to be taken apart and re-sealed.
You paid for it...Make them do it right.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 01:56 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 06:30 AM
Installing a Hot / Cold Water Spigot dc2295 Plumbing 1 02-25-2008 05:10 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
