Help With Small Leak In Bath Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2011, 05:41 PM   #1
Help with small leak in bath sink drain
I am asking for some help with a very small leak in a bathroom sink drain. The leak is at the trap joint just before it enters the final drain pipe under the sink. It is all plastic pipe, I just replaced that sink but can't stop the very small leak. I have tightened the joint and then tried to put teflon type tread tape to no avail. The treads on the trap look good. I am looking for some tips. I may try to put silicone on the joint and reassemble. Any other ideas. It is just a couple of drops after and hour or so. Thanks for any ideas. Jim
Binski is offline   Reply With Quote
Old 12-02-2011, 06:14 PM   #2
Rewards Points: 472
you dont use teflon tape on any of those fitting's Or silicon . Their should be a plastic bushing .Make sure it is in their their right way i bet it isn't. The bevel side should go to the trap and the nut will tighten it down and no leek.
del schisler is offline   Reply With Quote
Old 12-02-2011, 06:36 PM   #3
Thanks for the reply. The front of the fitting that houses the tailpipe does has a plastic bushing, it is installed correctly and does not leak. The back side of the trap is reversed (kinda of upside down) and it does not have a seperate bushing. Perhaps it is missing? I didn't thinK that side had a white plastic bushing like the tailpipe side ?
Old 12-03-2011, 09:20 AM   #4
Rewards Points: 1,568
Binski: Send some pictures. I don't understand the "The back side of the trap is reversed (kinda of upside down) and it does not have a seperate bushing. "
It is ok to use pipe dope and/or teflon tape on plastic fittings. Try the dope first; both if still leaks.
bob22 is online now   Reply With Quote
Old 12-03-2011, 03:15 PM   #5
i think i know the pipe you're speaking of. if it is it usually doesn't have a gasket or nylon ring (i'm saying if it is plastic) it usually has a sort of dome at the end of the pipe. these have to be perfectly aligned or they can leak. sometimes it helps if you put a coating of silicone on the dome before snugging it down, but i'd try the alignment first.hth
fullpint is offline   Reply With Quote
Old 12-03-2011, 04:46 PM   #6
Smile
Thanks for all the replies. I took the pipe apart again (for the upmteenth time) this morning. I looked very closely at the plastic gasket and it had been aligned but there was a small piece broken off inside near the base. It was very hard to see. Got a new part and all is well. The replies were helpful and got me on the right path. Thanks again! Jim
Old 12-03-2011, 10:54 PM   #7
Glad all is well; amazing what a $0.50 piece of new plastic will do.
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
I need Help Real Bad!! Drain Leak in Tub... harryjay97 Plumbing 7 12-10-2010 05:33 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
