-   -   Help with small leak in bath sink drain (http://www.diychatroom.com/f7/help-small-leak-bath-sink-drain-125363/)
Binski 12-02-2011 04:41 PM
I am asking for some help with a very small leak in a bathroom sink drain. The leak is at the trap joint just before it enters the final drain pipe under the sink. It is all plastic pipe, I just replaced that sink but can't stop the very small leak. I have tightened the joint and then tried to put teflon type tread tape to no avail. The treads on the trap look good. I am looking for some tips. I may try to put silicone on the joint and reassemble. Any other ideas. It is just a couple of drops after and hour or so. Thanks for any ideas. Jim
del schisler 12-02-2011 05:14 PM
you dont use teflon tape on any of those fitting's Or silicon . Their should be a plastic bushing .Make sure it is in their their right way i bet it isn't. The bevel side should go to the trap and the nut will tighten it down and no leek.
Binski 12-02-2011 05:36 PM
Thanks for the reply. The front of the fitting that houses the tailpipe does has a plastic bushing, it is installed correctly and does not leak. The back side of the trap is reversed (kinda of upside down) and it does not have a seperate bushing. Perhaps it is missing? I didn't thinK that side had a white plastic bushing like the tailpipe side ?
bob22 12-03-2011 08:20 AM
Binski: Send some pictures. I don't understand the "The back side of the trap is reversed (kinda of upside down) and it does not have a seperate bushing. "
It is ok to use pipe dope and/or teflon tape on plastic fittings. Try the dope first; both if still leaks.
fullpint 12-03-2011 02:15 PM
i think i know the pipe you're speaking of. if it is it usually doesn't have a gasket or nylon ring (i'm saying if it is plastic) it usually has a sort of dome at the end of the pipe. these have to be perfectly aligned or they can leak. sometimes it helps if you put a coating of silicone on the dome before snugging it down, but i'd try the alignment first.hth
Binski 12-03-2011 03:46 PM
Thanks for all the replies. I took the pipe apart again (for the upmteenth time) this morning. I looked very closely at the plastic gasket and it had been aligned but there was a small piece broken off inside near the base. It was very hard to see. Got a new part and all is well. The replies were helpful and got me on the right path. Thanks again! Jim
bob22 12-03-2011 09:54 PM
Glad all is well; amazing what a $0.50 piece of new plastic will do.
