Help Sizing A Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2008, 07:56 AM   #1
Rewards Points: 162
Help sizing a gas line
Hi,
I'm going to be running gas lines to previous electric appliances in my cabin and want to make sure I'm sizing the new main line correctly. Here's a quick sketch of my configuration - hopefully it makes sense. Each appliance noted below will branch off the main with a tee and dedicated line to feed it. Can someone help me with the proper size for the pipe sections marked as A,B,&C below?
Incoming (1") ------ 100k BTU furnace ---(A?)--- 40 gal water heater ---(B?)--- gas dryer --- (C?) --- gas range
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 11-30-2008, 09:45 AM   #2
what are the distances from the main supply for each appliance?
Orangeguy is offline   Reply With Quote
Old 11-30-2008, 12:14 PM   #3
Rewards Points: 162
The range will be the furthest away. The amount of piping from the meter to the range will be 35-40'. The furnace and water heater are about 10' of piping from the main. The dryer would be about 20'.
Old 11-30-2008, 12:38 PM   #4
this is of coarse assuming the following btu values to be close to what you have in your home!
a 45000 btu water tank @ 10 feet 1/2" id iron pipe
b 30000 btu dryer @ 20 feet 1/2 id iron pipe
c 50000 btu gas range(cooktop) @40 feet 1/2 "id iron pipe
be sure to drop pipe sizes like this
1' in to 1st tee 3/4" to furnace then 3/4" to next tee 1/2" to water tank 3/4" to next tee 1/2" to dryer 1/2 to range!
remember to install a 4" nipple and cap as a sediment cup below each line in to the appliance.If you need further help let me know .Hope this makes sence!!let me know how it goes!
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
