Help With Shower Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2014, 10:05 PM   #1
Rewards Points: 16
Help with shower fixtures
Was over at some friends house looking at their new house. This was a flip house done by some realtors so I didn't expect very high quality but they did have an inspection done and thought this would have been caught. It appears when they redid the bathroom shower they did not secure the copper pipe to the the studs behind the shower wall. The shower head pulls in and out from the wall and so do the handles for the water. Question is - Is there any way to secure the shower pipes without tearing into the newly finished tiled shower walls, securing the pipes, and then resetting the tiles and the finishing things right? Looking for easy but been on the site long enough to know it has to be done right. Any suggestions would be appreciated.
Speckert is offline   Reply With Quote
Old 10-07-2014, 10:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 834
I know of no easy way to make these repairs but here are some thoughts-
Fill the shower arm escutcheon and the hole with adhesive caulk- or
Pull back the escutcheon and see if you can tighten the screws at the shower ell- or
Do an intense google search for a shower nipple that has an adjustable face washer on it. I have seen them before but can not remember who makes them- they're not common.
For the handle- remove the face trim and see if you can wedge blocking inside.
After saying all that- it is best to bite the bullet and open the wall from the back side, or front if you have to, and properly anchor the pipes
The Following User Says Thank You to TheEplumber For This Useful Post:
Speckert (10-08-2014)
Old 10-11-2014, 02:27 PM   #3
Rewards Points: 240
Can you go into the wall from the back side?
fa_f3_20 is offline   Reply With Quote
The Following User Says Thank You to fa_f3_20 For This Useful Post:
BlackTiger (10-11-2014)
Old 10-11-2014, 06:03 PM   #4
Rewards Points: 288
Like others have said, going in from the backside is the way to go. With luck the shower backs onto a closet or something. Open the bay that the shower valve is in from the height of the lowest loose part to the height of the tallest. Cut 2x4 to fit the width of the stud bay and secure the shower arm elbow to it. If it's pex, you can do this without cutting the line, if it's copper, it might be simplest to just cut it and couple it back together when you're done. A 1/2" nipple 4" long or similar can be threaded into the elbow, then stuck back through the hole the shower arm normally goes into to make sure you have it in the proper place. When you're all done you can just take the nipple out and thread your shower arm back in. Screw the 2x4 into the studs as best you can. Same operation for the shower valve and the tub spout elbow if that's separate.
BlackTiger is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Replacing fixtures and CVPC in shower pinkertonpv Plumbing 1 07-30-2009 06:18 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 04:08 PM
