HELP - Seriously Leaking Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2008, 05:13 AM   #1
JAR
HELP - Seriously leaking toilet
Our toilet on the second floor has a chain with a styrofoam ball on it (I have never seen one before) connected to the flusher, but when he toilet was flushed that ball got wedged between the water valve flap and the big ball (not sure what it is called) which is attached to a arm and rises as water enters back into the tank. This caused the toilet to run at full speed all day while I was at work. When I came home and the toilet was still running water had come through the ceiling below the toilet and floaded much of my down stairs below the toilet.
Once the styrofoam ball was unwedged the dripping from the ceiling eventually stopped and it has since dried. There was no water around the base of the toilet when this occured and I have NO idea how, why, or where the leak occured. Nor do I know whether once I replace the chain with the styrofoam ball and the toilet begins to work normal again, is there some type of unseen damage within my walls that I now have to be concerned with? Any help would be greatly appreciated!!!!
JAR is offline   Reply With Quote
Old 11-02-2008, 06:06 AM   #2
Eibwen
If it flooded that bad you'll probably need to pull down the wet areas of the first floor ceiling and any insulation if any. Its got to have some air flow to dry out.
The toilet should have been able to run like that all day and not flood so you'll need to locate the source of the leak and correct that so it doesnt happen again. May be as simple as a partialy clogged line.
If you have homeowners insurance this may be a good time to take a look at a claim.
Sammy is offline   Reply With Quote
Old 11-02-2008, 07:07 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
JAR,
If you file any claim on homeowners insurance, it goes to a central agency that tracks claims for all insurance companies. They get concerned especially about water-damage claims due to the potential for mold and mildew.
If you file a claim, make certain that you also get an "all clear" statement from a certified mold-and-mildew mitigation specialist for the record.
There have been a lot of water-damaged homes (NOT just in floods) that have become uninsurable due to mold and mildew. THAT can be a financial nightmare.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-03-2008, 04:28 PM   #4
Rewards Points: 900
Also, check any wiring that might have gotten wet. Water can cause corrosion to exposed copper (such as in a light fixture), leading to a problem later.
Ultrarunner2017 is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaking Toilet Boongoon Plumbing 7 11-04-2008 05:44 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
toilet leaking, maybe? Gramps Plumbing 9 09-14-2008 12:31 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
