***********help Septic Is Backing Up Into Shower************ - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2008, 07:43 PM   #1
We just moved into our new home this week. Which is about 4 / 5 years old.
My husband took a shower in the 2nd bathroom today to try it out and water was pouring through our recessed light in the kitchen.
A few hours later, poop and toilet paper blasted through the drain in that shower.
What in the world is going on??? HELP.....
jlgchia is offline   Reply With Quote
Old 05-23-2008, 07:49 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The line is plugged up going to the septic tank, it need to be cleaned out.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-27-2008, 02:50 AM   #3
AZA
We'd be glad to help.....
Sounds like the line needs to be snaked or the septic tank hasn't been emptied.
AZA is offline   Reply With Quote
Old 05-27-2008, 08:25 AM   #4
cru
Could be a few other things to like roots, grease poured down lines ect. I would get it pumped out then go from there.
cru is offline   Reply With Quote
Old 05-27-2008, 08:50 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like a clog in the main drain line.
A 4 or 5-year-old septic system should not be having any problems whatsoever, although it may be about due for a "routine maintenance" tank pump-out ($250-$300 here), which should be done at least every five years.
Open a main drain clean-out plug (watch out for the backflow) and sanke the main drain line with a heavy-duty plumber's snake or call a plumber or drain cleaning company.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-28-2008, 12:39 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Do you actually have a septic tank, or is it a sewer basin with a pump ?
Journeyman Plumber
Can a septic line make right angles? Randell Tarin Plumbing 7 01-26-2008 09:01 PM
40s home still on Septic Tank? Inspection? twilightcall Plumbing 4 01-11-2008 07:35 AM
Maintenance for Septic System wibass Plumbing 1 06-26-2007 04:12 AM
Public Septic handy man88 Plumbing 3 05-25-2007 10:35 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 10:08 AM
