-   -   ***********help Septic Is Backing Up Into Shower************ (http://www.diychatroom.com/f7/help-septic-backing-up-into-shower-21391/)
jlgchia 05-23-2008 07:43 PM
We just moved into our new home this week. Which is about 4 / 5 years old.
My husband took a shower in the 2nd bathroom today to try it out and water was pouring through our recessed light in the kitchen.
A few hours later, poop and toilet paper blasted through the drain in that shower.
What in the world is going on??? HELP.....
Ron The Plumber 05-23-2008 07:49 PM
The line is plugged up going to the septic tank, it need to be cleaned out.
AZA 05-27-2008 02:50 AM
Sounds like the line needs to be snaked or the septic tank hasn't been emptied.
cru 05-27-2008 08:25 AM
Could be a few other things to like roots, grease poured down lines ect. I would get it pumped out then go from there.
Mike Swearingen 05-27-2008 08:50 AM
Sounds like a clog in the main drain line.
A 4 or 5-year-old septic system should not be having any problems whatsoever, although it may be about due for a "routine maintenance" tank pump-out ($250-$300 here), which should be done at least every five years.
Open a main drain clean-out plug (watch out for the backflow) and sanke the main drain line with a heavy-duty plumber's snake or call a plumber or drain cleaning company.
Good Luck!
Mike
Alan 05-28-2008 12:39 AM
Do you actually have a septic tank, or is it a sewer basin with a pump ?
:whistling2:
