Help!!! Roto-rooter Cable Is Now Stuck In Sewer Line And Won't Come Out!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2010, 06:59 AM   #16
Originally Posted by chrisn View Post
quote" Now I get to reset the two toilets and then take a good, long, hot shower. For the past 2 months I had to shower in just a trickle of water, now I know why. No reason to continue that now, the main line is clean as a whistle and I can get a decent flow going"
I am trying to understand what the main line would have to do with the flow of the shower??
What does your quote have to do with this thread?? You sure you didn't confuse it with another one you were writing to??
SULTINI is offline   Reply With Quote
Old 01-27-2010, 08:21 AM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
he hasnt been able to use a lot of water because main was backing up
plummen is offline   Reply With Quote
Old 01-27-2010, 10:32 AM   #18
DIY Junkie!!
Rewards Points: 180
The main line was so stopped up with roots that it would not drain, or at least if it did it was like water seeping through a sponge, VERY slowly....at times all I would need to do to end up with sewage and water standing in the tub was to pour a 3 gallon bucket of water into the dry tub or even just flush the toilet. I could take a VERY short shower at very low flow after letting the sewer line drain all night, but even at a low flow the main line would back up quickly (b/c it couldn't drain as fast as the water was exiting the tub) and leave me standing in raw sewage. The only way I could get a shower was to use a very low flow to get wet, stop the shower while I lathered up, then rinse very quickly with a low flow. Believe me, looking down while showering only to find that the tub is filling up with water, mixed with raw sewage, is absolutely NOT the way to get clean!
Last night was totally different--I could shower at full flow and flush the toilet at the same time and no backup, just like it was before the roots invaded that union.
It wasn't a deficiency in the shower's ability to deliver a full flow, thank goodness (I don't need those kind of problems, too )!!
Dugly
YerDugliness is online now   Reply With Quote
Old 01-27-2010, 10:43 AM   #19
Learning by Doing
Leah Frances's Avatar
This is considered torture at my house.
Thanks for clearing that up! It might not have been clear for some.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-27-2010, 11:20 AM   #20
DIY Junkie!!
Rewards Points: 180
I LOL , Leah, really! Thanks for that!
Yeah, I am fortunate, my home doesn't have problems with scalding when a second cold water source is used.
I did reach out and flush the toilet a few times in rapid succession as I showered last night just to test-check the flow capacity of the sewer repair. Worked fine! I've been pouring various "Draino" type products down the drain for the past 2 months with little success, and finally NO success, so having the city come fix it was the only option.
Like you, I really appreciate that the city stepped up, but I knew they would not have done so until I had tried all options and not been able to resolve the issue.
Once they saw that water standing for 2 hours at the top of the clean-out, they were convinced, AND they were quick to get into action.
I never dreamed that getting that Roto-rooter stuck in the main line would be an issue, though! Live and learn !!
Dugly
Old 01-28-2010, 01:31 AM   #21
What a story! Sometimes it just pays to have a pro do the work. My 2nd bath was being tiled Monday and Monday nite BR # 2 decided to stop up and back raw sewage into the tub--not good since I have only 2 bathrooms. Called a plumber that AM and he was there in an hour. I would not have tried to run a roto router myself. I am glad you got the poblem resolved but you are really braver than I am.
Bevgo is offline   Reply With Quote
Old 01-28-2010, 04:04 AM   #22
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
Dugly
Got it now, thanks for the explaination, what a mess!
