Help Rerouting Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2010, 03:14 PM   #1
Help rerouting tub drain
I need some help. I am rerouting a 1st floor tub drain to a new roughed in pipe. The issue I am having is that it used to be a shower in the basement there and the pipe from the floor does not reach out anymore. Its down a bit. Looks like from removing the shower it was chipped away at the top.
My question is do they sell or make an adapter to go on the INSIDE of a roughed in pipe (Looks to be about 2 inch inside diameter with measurement), that turns into a standard 1 1/2 on the other side? I would clean up the edges a bit and clean the inside of the pipe first.
Here is a picture of the roughed in drain I am planning on using. Going into this will be a sink directly over this and a tub that is above this room on the 1st floor. Will use a Y above this hidden inside a vanity.
PICTURE:
MY PLAN:
Thank you for any help!
HuskySkull is offline   Reply With Quote
Old 01-24-2010, 03:58 PM   #2
Found what I am looking for here.
http://www.plumbingsupply.com/pvc.html
Pipe extender - Spigot x internal spigot
rerouting shower drain PAIN! ericosuave Plumbing 27 01-26-2010 02:46 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
