#1 |
Help replacing stem valve assembly for washing machine
Hi everyone! I'm looking for some advice on replacing an older stem valve for a washing machine hookup. House is 1970's build.
Here is what I'm working with (note: pictures below show new valves installed). On/off up top and the hookups down below: ![]() Larger image: http://i.imgur.com/XItU2.jpg ![]() Larger image: http://i.imgur.com/Y6m7N.jpg Here are the details of the OLD valve (I think it's a Price Pfister 3204): ![]() Larger image: http://i.imgur.com/qpjXg.jpg ![]() Larger image: http://i.imgur.com/bvNEi.jpg I've checked three local Plumbing supply houses and no one was able to match my existing valve. Below-left is the best that they could do (PF S10-375 132440 - note that the newer valves threads are a bit longer): ![]() Larger image: http://i.imgur.com/kUj6T.jpg The plumbing shop suggested doubling up on the washers to get closer to the original length. What I've done is triple the washers and screw the valve right in. I didn't use any teflon tape, pipe dope or grease. Problem: With the main on and valves turned OFF I get one drip (#2 below) about every 20 minutes). With the valves turned ON I get major spraying all around the washers at position #1. I first hand tightened it, then continued slowly tightening to see if I could get the dripping to stop. I'm at a point now that I feel that I'm over-tightening it and I'm afraid of stripping the whole assembly. That's it. ![]() Larger image: http://i.imgur.com/wCQOe.jpg Any suggestions on what the problem might be or how to resolve it? Any ideas where I could get a better replacement for the original valve? I'd like one more attempt at it before calling in a plumber. ![]() Thanks! Last edited by a12733861; 01-10-2012 at 10:19 PM. |
#2 | |
MarginallyQualified
None of your images are coming through.
Pick one and *attach* it here (use the paperclip icon). That said... fixing a 1970's anything is probably of questionable merit. Maybe an old Chicago or T&S... Quote:
Is it replacable? Last edited by TarheelTerp; 01-10-2012 at 10:35 PM. |
#3 |
Help replacing stem valve assembly for washing machine |
#4 |
MarginallyQualified
#5 |
well it looks like you are in for some plumbing 101....don"t waste time trying to repair ...its time to replace...ben
#6 |
http://plumbing.hardwarestore.com/51...ox-636540.aspx
Time for a change. |
#7 |
Master Plumber
2 – ¾ tees 2 - ¾ arresters 2 – ¾ hose bibs... first time I see fixture zone valves used in that application. Or as my colleague pointed out use the pre fab box
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
Thanks everyone! Good or bad I ended up teflon taping the connection and it seems to be holding up. I'll keep an eye on it for a few days and if it still leaks I'll try out the suggested pre fab box.
Thanks again... |
| Display Modes | |
| Help on bathtub faucet stem valve | dhjunkie56 | Plumbing | 2 | 03-05-2011 06:14 PM |
| bad valve washing machine?? | drdon51 | Plumbing | 6 | 06-29-2009 02:02 PM |
| washing machine supply valve leaking | tina2435 | Plumbing | 9 | 01-24-2009 05:17 PM |
| Need help replacing shower diverter valve | magnolia | Plumbing | 9 | 07-12-2008 10:54 PM |
| Replacing water heater drainage valve | darsunt | Plumbing | 2 | 10-08-2007 10:17 PM |
