Help With Replacing A Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 03:01 PM   #1
Help with Replacing a Shower Faucet
I've replaced the drain switch, the shower handle and shower arm in my shower with new brushed nickel finished pieces, but I cannot seem to find a suitable replacement for the shower faucet. (see attached picture) The threads are on the back of this fitting that I don't recognize. I'm not sure how the fitting is attached to the copper nipple, but I've tried to unscrew it and tug on it a little with no luck. Does anyone know what this fitting is and if they make shower faucets to fit it? It's about an inch in diameter.
I bought a faucet suitable for rear threads, but it is too small to fit over this strange brass fitting.
adodd87 is offline   Reply With Quote
Old 01-19-2012, 03:06 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Ayuh,... That's part of the old faucet, 'n it needs to Go...
It's probably threaded, Behind the wall...
Old 01-19-2012, 03:08 PM   #3
Rewards Points: 12,794
Look for a tiny set screw in the bottom of it.
It was suppost to be loosened before the nozzle came off all in one piece.
Old 01-19-2012, 03:15 PM   #4
Thanks guys. I'll check for the set screw when I get home.
Old 01-19-2012, 07:05 PM   #5
Rewards Points: 582
you could check with a delta dealer on the spout that should fix that issue it looks like pop up spout adapter for delta....they have brushed nickle finish?????
Old 01-19-2012, 07:09 PM   #6
I just checked and there was no set screw on the fitting.
Old 01-19-2012, 07:13 PM   #7
Rewards Points: 582
if not mistaken that should unscrew...hold tight up and push down to loosen so you don't brake in back...leverage....
Old 01-19-2012, 07:18 PM   #8
If there is no set screw, it is probably soldered on.
broox is offline   Reply With Quote
Old 01-19-2012, 07:25 PM   #9
DIY staff
Rewards Points: 7,174
That's a Delta fitting--
It is soldered onto the stub out.
Buy a Delta tub spout or unsolder that and build what you need---
(resize your picture if you can)---Mike---
Old 01-19-2012, 07:32 PM   #10
Rewards Points: 582
never seen one of delta spout ends soldered on????maybe just me....always have 1/2" ips female adapter?????maybe just me?????I am getting old though
Old 01-19-2012, 08:03 PM   #11
DIY staff
You will--The last three that I installed were solder on fittings.
Dumb design--but true.
ben's plumbing (01-19-2012)
Old 01-21-2012, 08:43 PM   #12
Thanks for the help guys. I used a torch to heat it up and sure enough it popped right off. Not a great forward-thinking design to solder it on like that.
The Following User Says Thank You to adodd87 For This Useful Post:
ben's plumbing (01-21-2012)
Old 01-21-2012, 09:09 PM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 984
There is a reason why it's done like that.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-21-2012, 09:19 PM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 984
A close relative of the part you removed.
Old 01-21-2012, 09:19 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 348
I actually like that design. Cut the stub out to length, sweat on fitting and screw on spout. No stinking allen screw to look for..
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Replacing shower head and faucet puzzle, moen to kohler rjwrightohio Plumbing 3 11-07-2011 08:02 AM
Replacing 2 handle faucet with single handle faucet vcheez Plumbing 6 10-19-2011 11:26 AM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 01:08 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 08:55 AM
