Help! Replacing This P Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2013, 06:06 PM   #1
Question
Help! Replacing this P trap
Is it possible to replace this setup with ABS?
That is how it was originally set up, I tried removing the U trap to clean but it was rusted and broke from the 90 bend pipe. The U trap and the 90 bend both broke off and unfortunately the 90 bend pipe is either soldered or glued to the main drain pipe. How can I replace this without spending $$$$$$$ on a plumber as its something we can't afford at the moment. I am not really familiar with plumbing but I am trying my best!
malbrax is offline   Reply With Quote
Old 07-17-2013, 06:18 PM   #2
Rewards Points: 6,652
Just like it is in the first picture. So again, is there a question here.
Old 07-17-2013, 06:25 PM   #3
Yes the question is how.. Sorry I am not really good with plumbing I am not sure on how to replace the 90 bend pipe with ABS and join with the main line. Do I have to replace the sink drain as well? or will it fit with the ABS
Old 07-17-2013, 06:37 PM   #4
Rewards Points: 13,712
The whole set up is sold as a set, with one added piece called a tail piece extension.
The extension is the short piece attached to the bottom of the drain.
The whole set up is less then $10.00.
More likely it's going to be PVC not ABS but both will work.
Any hardware, or box store will have them.
Only comes in two sizes 1-1/4 and 1-1/2. Just measure the pipe.
The was no picture of the drain adapter that you think may be soldered.
Most use a nut with a flat rubber washer to seal the drain adaptor, but it's not unheard of to see solder instead.
Going to need a propane torch if it is to get it out.
jmon (07-17-2013)
Old 07-17-2013, 06:48 PM   #5
Rewards Points: 258
Or just cut it with saws all
redman88 is offline   Reply With Quote
Old 07-17-2013, 06:51 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 676
The proper way- cut the copper stub back at the end of the chrome tailpiece.
Sweat/solder to the stub a 1.25" brass trap adapter.
Now you can add a 1.25" plastic trap.
With this set up you can service the trap in the future
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
DannyT (07-17-2013), jmon (07-17-2013)
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Replacing old brass drum trap dukes32 Plumbing 12 12-23-2012 04:01 PM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
