Help Replacing Kitchen Faucet (no Nut Under Sink) - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2010, 06:59 PM   #1
Help replacing Kitchen Faucet (no nut under sink)
Handle sheared off yesterday, so I went to replace & never seen this before. There is no nut underneath the sink/faucet. Just sort of a metal half circle & the water hoses running down.
Top:
Bottom:
Thinking of just chucking the sink & everything, but just finished a large bathroom re-model & the kitchen is planned for 2012.
Any help/suggestion would be great!
Thanks!
James
deathandgravity is offline   Reply With Quote
Old 12-09-2010, 08:14 PM   #2
HVAC / Plumbing
that kinda clips on. easier to take off with sink out
kenmac is offline   Reply With Quote
Old 12-09-2010, 08:33 PM   #3
You are looking at a moen Kitchen faucet. You can get new parts including the handle assembly from Moen directly the faucet has a lifetime warranty. If you want to remove the faucet from the sink. You need to loosen the sprayer hose from the spout shank. Then loosen the nut holding the c shaped clamp. Then remove the nut on the soap dispenser, and the nut on the sprayer mount. The faucet will pull off of the sink with no worries. You can save yourself alot of grief by going to Home Depot, Lowes or Menards, and purchasing a basin wrench.
You can find this faucet along with an exploded parts diagram at www.moen.com
Work4living is offline   Reply With Quote
The Following User Says Thank You to Work4living For This Useful Post:
the_man (12-09-2010)
Old 12-09-2010, 09:35 PM   #4
Rewards Points: 121
There is no nut underneat...
Never mind,...no good would come from a comment...
JoeLena is offline   Reply With Quote
Old 12-09-2010, 10:08 PM   #5
This link should get you your parts diagram.
http://www.moen.com/shared/pdf/7439pt.pdf
Old 12-09-2010, 11:19 PM   #6
Thanks for the help! I really appreciate it.
Cheers
Replacing parts of a kitchen LilDave Kitchen & Bath Remodeling 7 04-09-2010 07:42 PM
Kitchen Sink Supply Lines Steven Z. Plumbing 3 04-02-2010 10:14 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
