#1 |
Help replacing ball valve
I am replacing a ball valve for my sprinkler vacuum breaker. It is threaded on both ends but one end is leaking. Is there a way to unscrew the valve without cutting the pipe or unsoldering a joint? It is threaded on both end but each end spins a different way to tighten.
#2 |
It's anyone guess as to what you have without a picture.
#3 |
The valve on the left is what I need to take off and add Teflon tape. Is there a way to just unscrew it, re tape it, and screw it back on?
#4 |
MarginallyQualified
You asked about this last week...
what became of that conversation? |
#5 |
Never got an answer! Same job different question. I assume I have to either cut pipe or desolder joint and remove threaded fitting. Re-tape and go from there was just hoping there was an easier way.
#6 |
To the left of the ball valve is a coupling. Take two wrenches and take the coupling apart. This will allow you to unscrew the ball valve from the breaker.
I don't know if they sell just the ball valve but you may find one at a large plumbing supply and/or sprinkler supply company....or on-line. If it was me.....I would separate both couplings next to each ball valve and replace the entire vacuum breaker. The old one should have a model number on it. You can always look on e-Bay. Good luck |
#7 |
Break the couplings with wrenches on the large nut and the male side of the coupling.
#8 |
call me E
If you break the unions apart, you can remove the vacuum breaker and valves. then you can do whatever you want to it. Thats the beauty of unions- they allow you to do what you're asking.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#9 |
sorry guys i posted wrong pic. The ones up now are of my vacuum breaker
#10 |
call me E
you have to cut the pipe to thread the valve on or off
| Display Modes | |
| Replacing a Pressure Relief Valve for a Boiler | multiphrenic | HVAC | 18 | 11-30-2011 12:16 PM |
| Leaky ball valve at incoming water line | Bipin1948 | Plumbing | 5 | 10-03-2011 06:21 PM |
| ball valve size? | Mark Rhein | Plumbing | 2 | 03-03-2010 10:46 AM |
| New ball valve leaking half open? | sz8 | Plumbing | 5 | 01-05-2007 11:46 PM |
| leaking 1 1/4" Brass Ball Valve | creemore | Plumbing | 2 | 03-11-2005 09:23 PM |
