Old 02-22-2009, 03:04 PM   #1
Default Help removing handle from sink faucet
OK, I've seen a lot of faucets in my life but I can't for the life of me figure this one out...
I'm trying to get to the valve stem to rebuild it, but I can't get the grooved ring off. It seems to be connected to the valve stem. In the last picture you can see how it normally looks with the decorative handle.
Any help is greatly appreciated!
dervari is offline   Reply With Quote
Old 02-22-2009, 05:50 PM   #2
plumbing contractor
PLUMBINGITALL's Avatar
Try using a handle puller
PLUMBINGITALL is offline   Reply With Quote
Old 02-22-2009, 06:29 PM   #3
So the center of the handle puller will go into that small hole in the middle? It's only about .125".
Keep in mind that the small hole is actually threaded to receive the screw that holds the actual handle (see last pic).
thanks!
Old 02-23-2009, 09:22 AM   #4
plumbing contractor
Yes that's correct it goes directly in the screw hole
Old 02-23-2009, 06:42 PM   #5
Bought one and tried it. The pin in the middle isn't long enough to make contact with anything.
Wouldn't there have to be some sort of screw or retainer to hole the "sleeve" down onto the stem?
Any more suggestions?
Old 02-23-2009, 06:52 PM   #6
011000100110111101101111
DangerMouse's Avatar
i'd think there'd be a set screw under the edge somewheres. that's a curious setup i've not seen before.
maybe it's a push clip that just needs a coat hangar down the center hole? hehehe idunno, please let us know how it finally comes off, ok? (for possible future reference)
thanks
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
DangerMouse is online now   Reply With Quote
Old 02-23-2009, 07:04 PM   #7
I'll definitely let you know when (if?) I'm finally able to take it off.
I've looked for a set screw but couldn't find anything alone the base or under it.
Old 02-23-2009, 07:28 PM   #8
you know what? i bet it's just sitting on there.... look carefully down the center, if there is a separation between the hole and the threads are further down, grab a flathead screwdriver and slip it under the edge and gently try to pry it off. i bet it pops right up.....
DM
Old 02-23-2009, 07:34 PM   #9
the screw held it AND the plastic, didn't it?
DM
Old 02-24-2009, 08:46 AM   #10
Man of many hats
wrangler's Avatar
I'd agree that the chrome piece is just siezed onto the splines on the valve stem. Might try prying it between the beauty ring and the chrome portion of the handle with a flat bar, turning it slightly with each nudge till it pops off.
Man of many hats
wrangler is online now   Reply With Quote
Old 02-24-2009, 11:53 AM   #11
plumbing contractor
If the puller will not work try using some type of rust spray and maybe two flat srew drivers under it and prise it up. It has to be just siezed on the stem
More On This Topic
Today we’re going to be redoing an older home sink and installing it. It has some rust around here, and more or less the drains are still really tight. You need to clean it with ajax first, and then we’re going to install the faucet first. So... Read More »
Today we have installed a new faucet on an older sink, which we’re going to put in our new kitchen remodel. What we’re doing is we’re just going to connect the supply hoses, which can be one standard size, but they’re not. Just... Read More »
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
You can easily install a water filter under your sink to clean the water before it leaves a special water faucet. These under sink water filters check for a large variety of harmful contaminates found in tap water, making the under sink water filters... Read More »
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 10:28 AM
Stuck Faucet Handle tech girl Plumbing 0 11-12-2008 07:16 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 09:12 AM
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 01:45 PM
vessel sink drain and faucet Katmac Plumbing 15 03-02-2008 03:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
