Help Prevent Future Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2008, 10:06 AM   #1
help prevent future problems
I am remodeling my shower soon. I will be removing a shower base and installing tile flooring. I am also cosidering altering my shower plumbing a bit, maybe dual shower heads or jets. I have heard that if you do things like this yourself and not by licensed contractor or plumber, it can cause problems when selling your home. I do plan on selling at some point in my life, has anyone had experiance with this or know somthing that would be helpful.
airassault is offline   Reply With Quote
Old 06-04-2008, 10:52 AM   #2
Registered User
Termite's Avatar
It is always a good idea to pull a permit for this type of work. That way you have evidence that it was done to the minimum standard of the code in your area.
I don't see any reason to pay a plumber to do it if you can do it correctly yourself. If something works wrong or looks odd, it would certainly attract attention at the time of sale.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 05:38 PM
