Help Plumbing In Coffee Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2006, 09:18 AM   #1
EspressoMan
Help Plumbing in Coffee Machine
I need to plumb in my espresso machine (professional machine) in my home. The snags I have are threefold.
1. I need to cut the botom out of a 30"x24" metal kitchen cabinet drawer. Is a dremel with cutting wheels best (sounds slow) or a hand held 3 or 4" grinder best? I will also need to cut through the bottom of the cabinet in the same manner.
2. I need to cut to holes cleanly through the countertop. One would be about a 2" round hole for the water and drain lines and the other would be a square cutout (with rounded corners) for the knockbox. Is there a particular bit I should use with the plunge router? I've never used a router nor a hand grinder before.
3. The plumbing is steel and quite old in my house. The inline fawcets have little 1/4" fittings on them with brass caps. Are those available to attach a 1/4 water line?
Thanks.
singforsupper is offline   Reply With Quote
Old 08-19-2006, 09:29 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
1 and 2........ Is this Stainless Steel?
3. Yes you should beable to adapt or connect to the existing water supply.
Ron The Plumber is offline   Reply With Quote
Old 08-19-2006, 10:28 AM   #3
renovations
What material is your countertop? Laminate? If you haven't used a plunge router before I strongly suggest you go to a place that installs laminate counters and get a sink 'cut-out' (That's the piece of countertop that they cut out and discard where the sink goes). You could practice on this. You'll need protective gear and be prepared for the mess, routers really throw dust.
How big is the square hole you want to make? If it's bigger than just a few inches I'd suggest drilling the corners and then using a jig saw for the rest.
Bonus is offline   Reply With Quote
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
Can a newbie move over a washing machine? yummy mummy Plumbing 17 02-15-2007 07:31 AM
Hi from OR: painfully-won plumbing tips ddc Plumbing 12 12-05-2006 01:33 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
