Help, Please Confirm My Plumbing Work! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 02:16 PM   #1
help, please confirm my plumbing work!
this is my new drain for the toilet, it goes into a 45, then a steep slope, then a 45 and into a 90 degree T, then down and into another 45........and then out! will the liquid and solid waste flow through this well or should the T be on a 45 too get rid of one more joint??
boddah is offline   Reply With Quote
Old 02-08-2009, 02:26 PM   #2
Old 02-08-2009, 02:27 PM   #3
the last 45 is not in yet. sorry i think my pics are too big, only one will fit per post
Old 02-08-2009, 02:32 PM   #4
one more thing, i have capped the old drain for the tub instead of removing it, is this ok?
Old 02-08-2009, 02:47 PM   #5
the only thing you might wanna look into is that where you have capped it, you put a compression fitting on... some places it is against code for those to be horizontal, they must be vertical. It should be fine, but some people like to be completely up to code. Maybe check it out.
I dont think there will be any drainage problems but something to consider when there are alot of elbows... Try replacing a 90 turn with a tee and put a threaded cap on the unsused end, This can be used as a cleanout if needed. Looks like good work.
scotty123 is offline   Reply With Quote
Old 02-08-2009, 02:48 PM   #6
Actually that cap you put for the tub is exactly what i meant as a cleanout.. depending on that location it is exactly what you need... you would be able to get in with a snake if it ever backed up.
Old 02-08-2009, 03:10 PM   #7
Isn't this one on upsidedown??
handyflyer is offline   Reply With Quote
Old 02-08-2009, 03:55 PM   #8
yes it is upsidedowndidnt notice it untill it took the picture, cause its pretty dark it that crawl space.
Want to tile bathroom - raise plumbing? wombosi Plumbing 2 11-13-2008 07:54 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
Trying to get swith to work... mntentman Electrical 4 09-19-2008 08:54 PM
photo cell lights thst only work sometimes... kemerick Electrical 10 11-10-2007 11:29 AM
