Help - Old Tub Drain Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2013, 07:29 PM   #1
Send a message via AIM to chsitko Send a message via Yahoo to chsitko
Hi, thanks in advance for any help or advice you can offer.
We have a house that was built 1960's. Our tub drain stopper had broken a couple of months ago and the family keeps letting baby rags into drain which becomes a real hassle to get out. So I want to replace the drain with a pop up stopper, but I can not get the old drain out. I thought all drains were threaded and screwed in, but im not so sure anymore. The common drain removal tools don't fit so I picked up the "drain key" which expands to fill the drain and then allows one to remove the drain, but it didn't work either.
Please see the attached pictures and let me know if I need to try a different approach. Do you know if it is a threaded drain or something else.
Chris
clicking the pictures should bring a larger image up.
chsitko is offline   Reply With Quote
Old 10-12-2013, 07:32 PM   #2
Rewards Points: 13,698
There all threaded.
Need one of these.
http://www.bing.com/images/search?q=...electedIndex=7
Old 10-12-2013, 08:10 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id use a dremel with a cut off wheel to slice it up into little pieces and pry it out,just be carefull not to cut into the tub.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-12-2013, 08:18 PM   #4
Any access under it?
A few are held in place with the nut under the tub.
Old 10-12-2013, 09:04 PM   #5
Joe, that's actually the exact tool i bought and tried. I dont think i was able to get in far enough because of the little tab sticking out in the drain. I'll try knocking it off tomorrow and see if i can get the tool in further.
I checked under the tub and there is no nut.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
Removal of Bathtub Drain joe3534 Plumbing 4 10-22-2009 08:41 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Mystery floor drain removal guzman@wwdb.org Plumbing 2 04-03-2008 03:29 PM
