Help With Odd Shaped Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2009, 11:42 AM   #1
Help with odd shaped faucet
Hi all, I need to replace a leaky faucet in my upstairs bath but the Big Box stores don't have anything like it (pic attached). Is this an easily found replacement part or should I replace the entire sink (wall mount) to avoid future problems?
I have previously replaced part of the faucet itself (the hot side) but the issue is back.
mikeperr1 is offline   Reply With Quote
Old 09-10-2009, 03:51 PM   #2
That's called a shelf-back faucet. In order to replace them you have to monkey around under the sink a bit.
Plumb And Light is offline   Reply With Quote
Old 09-10-2009, 04:04 PM   #3
thank you for the info.
Wow. . . Who would've thought those tiny things would be so expensive? I guess I will pull the entire sink out and replace with something more standard.
Old 09-18-2009, 11:30 AM   #4
I ended up finding a cheap replacement at my local plumbing supply store for about $100. Best advice I can give to anyone replacing this type of faucet it remove the sink off the wall. MUCH easier to work that way.
New Delta faucet drips Ultrarunner2017 Plumbing 10 02-28-2012 09:34 AM
Faucet Cartridge removal -- what should I have done? RippySkippy Plumbing 9 08-20-2009 08:49 AM
Another "Kitchen faucet replacement" thread! :) emperor_black Plumbing 3 07-27-2009 10:44 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
