Help New Toilet To Close To Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2012, 08:07 PM   #1
Help new toilet to close to wall
I am getting a new house built and they put the toilet in the bathroom today. I quickly noticed it was not centered between the wall and vanity. If you sit on the toilet you would hit your left arm on the toilet paper holder. It also looks bad. What kind of work will this entail? Is there a pretty easy fix? Just guessing, but I think it needs moved about 6-10 inches. Will the builder be responsible for fixing?
Jefftra is offline   Reply With Quote
Old 10-08-2012, 08:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
A toilet needs to be 15" from it's center- to the side wall or vanity. Thats code in my area. If it is within that 15" rule then they are compliant and the rest is cosmetic only
Perhaps there is a floor joist in the way? Moving it may involve opening a ceiling below, cutting out floor,, new pipe ect.
Old 10-08-2012, 09:13 PM   #3
I went in the house across the street, same exact house and it is on center unlike ours. It is definitely to close to the wall for comfort.
Old 10-08-2012, 09:22 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
1 and most imporantly : What does the building plan show?
2 : Did you discuss the location of the toilet with the builder during the framing stage?
3 : As e-plumber mentioned, is there a joist or beam in the way that would have to be cut out, and cause further footings to be set below the floor system?
Again, 15" from centerline of toilet to sidewall is minimum by UPC.
Journeyman Plumber
Old 10-08-2012, 09:25 PM   #5
Rewards Points: 582
is this on 1st or 2nd floor....6-10" is really off.. I would bring it to the builders attention...not really an easy fix...ben sr
Old 10-08-2012, 10:04 PM   #6
It's on the 1st floor. I didn't discuss anything about the placement of it. Never thought they would do this. I'm sure it was not on purpose. Like I said the house across the street, same model is just fine and centered. Im just guessing on the 6-10 because I didn't have a tape measure. I will tomorrow. I already sent a notice to the builder. They will have to fix even if it's not an easy fix.
Old 10-08-2012, 10:08 PM   #7
I think the joist are running in a direction where it wouldnt effect moving it. Have to go by tomorrow.
Old 10-08-2012, 10:23 PM   #8
Doing it myself
Alan's Avatar
Trying to think of reasons why I would put a closet flange 6 " - 10 " off, and I just can't think of any other than the reasons listed above.
That's not to say there aren't some real smart ones out there who would just make a blatant mistake like that, but perhaps the vanity cabinet size changed somewhere along the line and nobody told the plumber?
Keep us posted, i'm interested in what happened.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
ben's plumbing (10-09-2012)
Old 10-09-2012, 09:37 AM   #9
Rewards Points: 582
if its on the 1st floor ...its eaiser than the 2 nd floor.....how about the floor around commode....?????it will need repaired....or replaced???????ben sr
Old 10-09-2012, 07:43 PM   #10
Ok here is the latest. I emailed the builder and he said no problem. Thats an easy fix. I went over tonight and measured. Looks like it needs to be moved about 3.5 inches. Here is a picture. Also I looked in the basement. THere is nothing that will prevent moving the hole.
Help new toilet to close to wall-toilet-3.jpg   Help new toilet to close to wall-toilet-1.jpg
The Following User Says Thank You to Jefftra For This Useful Post:
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
wall mount toilet jjrbus Plumbing 8 11-12-2009 01:07 PM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 09:16 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
