Help With New Drain/vent/waste System - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2013, 04:13 PM   #1
Rewards Points: 489
Help with new drain/vent/waste system
I'm currently building my own house (HEAVY into DIY!) and have a few DVW questions. Mostly, I'm having trouble trying to figure out where to put clean-outs. According to the books, you should have one on the high end of every horizontal run. That will be a lot of clean-outs! What about areas where it's hard to fit one in? I have a 3" run draining two toilets that I would like to run through the floor joists. The problem comes with the clean-out. They call for 18" of clearance for a 3" clean-out, but the joists are only 16" apart. Can I drill a hole in the next joist for access? Theoretically, it's more than 18" clearance, but you'd have to bend the snake up between the joists. I'm not sure if an inspector would buy that. The only other option for this run would be to drop the 3" run below the joists- something I'd rather not do with an eye to finishing the basement someday.
The next issue is 3 fixtures in close proximity- a washing machine standpipe, a lavatory, and a shower. According to the charts, that's too much for a 2" drain. Should I combine them into a single 3" pipe, or run two separate 2" pipes?
Lastly- Does it matter whether a vent is 'upstream' or 'downstream' of a fixture? For example, I want to put the vent for a toilet in the wall behind it. This is 15" downstream, towards the main drain. It would be nearly impossible to place it upstream of the toilet. I don't think it matters, but can't find any reference to this.
Any help on these questions would be most appreciated. This all looked easy at first, but is quickly becoming complex. Our local inspectors aren't very helpful (or strict) but I want it to function well. Thanks!
MushCreek is offline   Reply With Quote
Old 02-26-2013, 10:00 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Which code are working under?
Here's some UPC rules-
Clean outs at the base of stacks
Clean outs after 135 degrees(90 & 45) on horizontal runs
Horizontal runs under 5ft- clean outs not needed except sinks & urinals
**Except the bldg drain and its horizontal branches- a cleanout is not required above the floor level of the lowest floor of the building
An approved cleanout is needed where the building drain exits the building
A cleanout may be extended in height by using approved drainage fittings- in your example, bring 3" up through the floor for the cleanout. But you probably don't need that clean out anyways. If you do- you can use the toilet vent if piped properly
The Following User Says Thank You to TheEplumber For This Useful Post:
Javiles (02-26-2013)
Old 02-26-2013, 10:24 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 984
If can draw a layout of how your going to place your fixture and post it, someone will draw a drain and venting layout for you,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-27-2013, 08:37 AM   #4
Rewards Points: 489
Here's a sketch of the area in question. The horizontal section of 3" is the one that could run through the joists, if I can fit it in. The branch going up in the pic services the washer standpipe, the lavatory, and the shower. I transitioned to 3", as 2" is not enough for the three fixtures (I don't think). The vent locations shown are laid out to fit interior walls. I can run a vent up an exterior wall, but the house is ICF, which means cutting a channel in the foam. 'WC' is a toilet, 'V' is a vent. The little arrows show proposed clean-outs.The funky 45 degree angles on the left are to work around a wall, and is under the stairwell. The main line with the two toilets would run through the joists or just under them, then drop down about 5', with the elbow having a 2" outlet for a vent, and then transition back to horizontal through the 45 degree angle, and then back in line with the main stack through another 45. I don't think I'll have enough space in the joists anyway, as I have the 3" branch coming in, which also has to have enough drop. The main 3" is about 12' long, and the 3" branch is about 8' long.
Old 02-27-2013, 09:00 AM   #5
Rewards Points: 3,130
I know what you're going through. My wife and I built our log home almost entirely by ourselves. Lived in our RV on the property for over two years while doing it. If you don't already have them, I highly recommended a couple of Code-Check books. There's one for plumbing and one for electrical. Maybe framing and structure too, but I didn't buy that one. The actual codes themselves are nearly incomprehensible to most non-professionals.
When I started laying out the DWV system, it soon became clear that proper venting was a total mystery to me. The applicable code at the time (2008) was IRC 2003, which approaches venting entirely differently from the UPC, which I was moderately familiar with. So what I did was pay a licensed plumber a few bucks to design what I needed and I put it in.
Old 02-27-2013, 09:30 AM   #6
running 3 inch pipe through your floor joists will make them to weak. no code i have worked under would allow it. the venting you show for the toilets will not pass code. if you can post a floor plan people will be able to help you better.
Old 02-27-2013, 11:08 AM   #7
Don't be too sure. Log homes are different. I actually think mine is seriously over-engineered. The floor joists are 2x12 at 16 oc for a 14-ft span. And those for the second floor are 4x10 beams at 24 oc, same span. But those are exposed, and more for looks than structure.
Old 02-27-2013, 11:47 AM   #8
Plumber
Rewards Points: 348
I would love to give you some help. But I don't know what code you work with and I have a hard time understanding your drawing. Per UPC- you're all messed up. Very little of your venting is correct. I suggest reading up on venting or as suggested, hire some qualified help
Old 02-27-2013, 12:38 PM   #9
Rewards Points: 489
We're under IRC 2006. The joists are TJI's, and I would have enough room to drill them for 3" PVC. That being said, I don't think they are tall enough to allow for the amount of pitch I need.
The venting is a puzzle. I have a code help book, and 2 other plumbing books, and they are very non-specific about where the vents need to be. They say how far away they can be (all 3 books differ on this) but they don't say where they must be in relation to the fixture. What is wrong with the venting? The toilet ones are both downstream of the fixture- should they be upstream instead? If so, I will have to branch off of the main line, and tunnel them up through the ICF foam. As shown, they are all well within the required distance. I have seen diagrams of both upstream and downstream locations for vents.
Old 02-27-2013, 12:46 PM   #10
Plumber
Rewards Points: 348
I don't know IRC, I believe there are some plumbers here that do though.
What I can tell you per my code is that vents belong on the branch or fixture trap arm- not the building drain. Perhaps a IRC guy will chime in
Old 02-27-2013, 02:07 PM   #11
Rewards Points: 489
Something more like this? The drain next to the lav is the washing machine standpipe; I don't think they need to be vented as it's open to the atmosphere. I don't think the lav next to the main stack needs a separate vent(?)
Old 03-01-2013, 06:34 AM   #12
Rewards Points: 489
No further comment? If I wanted to hire a plumber, I would have- this is a DIY forum. My current fairly new house was plumbed by a professional. The master lavatory drain is so high in the wall that it barely drains, and clogs easily due to slow flow. When you run the washing machine, it bubbles up in the master toilet, sometimes with soapy water. If you flush the toilet during the wrong part of the cycle, the toilet will back up and over flow. I'd like to think I can do better than that. I can't tell what they did wrong without tearing out the drywall, so I'm going to focus on my new house. I'm still looking for feedback- Thanks!
Old 03-01-2013, 09:17 AM   #13
If your house was indeed plumbed by a licensed plumber and passed inspection, you have a clog somewhere. Probably in your main sewer line.
As for the lack of comments, please understand that the IRC is used in far fewer places in the U.S. than the UPC, so correspondingly fewer plumbers know it. And in some respects, the two codes are quite different. I'll repeat my earlier suggestion that you pick up a Code-Check book for plumbing. It covers both codes and has lots of useful illustrations.
Old 05-17-2013, 05:55 AM   #14
Rewards Points: 489
An update- I continued my research, and believe I have a valid design now. I had to re-work the shower to get it right. In the course of my research, I found out that the under slab plumbing that was done by a professional is wrong, but will probably work OK. It is for a basement bathroom that will rarely be used. I wish I knew more about this before I signed off on the work and buried it under concrete. The inspector didn't catch it, either. My two experiences with professional plumbers have been 0 for 2. That explains part of why I'm building my own house.
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 08:18 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
