Old 05-12-2010, 08:58 PM   #1
Question
Help Needed With Installing Closet Flange
Hello,
I'm trying to install this closet flange:
There is a 90 degree elbow just below the concrete so my flange bottoms out when I try to push it down into the drain pipe:
Can I trim a couple inches from the bottom of the flange?
Is there anything I can do besides breaking up the concrete? There's only about 3/4" of the stub above the concrete.
In addition, the concrete is "mounded up" a bit around the stub and not level. How can I level this out so my flange sits flat on the concrete?
Here are some more photos:
Thanks all!
NickGriffith is offline   Reply With Quote
Old 05-12-2010, 09:34 PM   #2
GC/Master Plumber/Mech
Won't happen using that flange into that 90
Do this;
Trim the PVC coming out of the floor flush with the floor
Remove the what appears to be a PVC ring inside the 90
Buy a flange ring repair kit and anchor it to the concrete around the pipe. Use tapcon screws
Install closet bolts, wax ring and then the toilet
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 05-13-2010, 08:34 AM   #3
Thanks for your reply.
The outer layer is a coupler. Should I still cut out the inner layer of PVC above the 90?
So I am looking for something like this?
And you're saying I won't need a flange, just the piece shown above?
Old 05-13-2010, 09:05 AM   #4
Military Mom of 4
Snav's Avatar
Yes, that's what he's talking about.
Cut the pvc coming out?
That depends on the type of flooring you'll be putting into place - will you be laying tile? If you will be then take the thickness of your new floor into account.
If no thicker flooring then, yes, cut the pvc flush and install the new flange - your wax ring for your toilet will make the transition smooth.
The toilet flange has 2 functions. #1 - it attaches your pipe to your toilet. #2 - it attaches your toilet to the floor. So by replacing the 2 in 1 pvc unit that you do have you will be using the new flange to take care of #2 - and the screw-fittings that attach your new flange to the floor will assist with #1.
Sometimes the convenient 2/1 products such as a toilet flange with pvc stem don't solve all the problems.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 05-13-2010, 09:27 AM   #5
I will be installing porcelain tile so I shouldn't cut the PVC flush with the concrete floor, more like flush with the height of the tile, right?
So I'll install the toilet flange repair ring directly on the concrete using tapcons:
Then the wax ring sits directly on this stainless steel ring and I'm good to go?
Any ideas for leveling the slab where the concrete guys mounded it up around the stub?
Thanks so much!
Old 05-13-2010, 10:25 AM   #6
Military Mom of 4
Snav's Avatar
If you're using the replacement ring it might be best to cut the pvc flush, install the flange to the floor and then use spacer flange pieces (small plastic ring(s) that you silicone together to make up the gap between the surface of the new flange and the bottom of the toilet.)
Old 05-13-2010, 09:29 PM   #7
Install the tile and cut the pipe flush with the top of the tile. Then install the ring on top of the tile
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Tiling around tub with very wide flange petsparkle Kitchen & Bath Remodeling 3 04-20-2009 04:53 PM
What to do with Closet flange jenoble99 Plumbing 1 01-05-2009 02:56 AM
Closet flange: flush with finished floor, on on top of? rjhaleymd Plumbing 4 11-20-2008 07:43 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 03:30 PM
