Help Needed Identifying Bathtub Faucet/handle Connector - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2011, 10:24 AM   #1
Unhappy
Help needed identifying bathtub faucet/handle connector
Hi all,
I recently remodeled my bathroom, and like a genius I threw away the old bathtub faucet and handles, so I have absolutely no idea what brand I need to buy that will be compatible. I've attached two images. Hopefully somebody can help.
tatertoten is offline   Reply With Quote
Old 12-02-2011, 07:39 PM   #2
Rewards Points: 81
You could always remove the valves and take one to the store with you to check handles for fit. The whole valve unit will unscrew with a large socket (probably 1 inch or so) or you can use a valve tool which is basically a really deep socket.
Just make sure you turn off the water to the house first!
JeepNick is offline   Reply With Quote
Old 12-02-2011, 08:26 PM   #3
Rewards Points: 582
looks like it could be a delta....thats just me...you might have to replace it if you do get a delta...
Old 12-03-2011, 02:23 PM   #4
...i agree, looks like a delta.
fullpint is offline   Reply With Quote
Old 12-03-2011, 03:05 PM   #5
Rewards Points: 14,006
The handle part is easy, any univeral handle kit will work, did you also throw away the flange that keeps water from getting in behind the handles?
I have the exact handle set up on the faucet I just redid a bathroom in and the universal handles fit.
Help identifying part - connector diy355145 Electrical 3 12-25-2010 04:44 PM
bathtub reinforcement needed? tpagel Remodeling 6 12-16-2009 06:30 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
SS flexible connector with nut? oldnightnurse Plumbing 38 05-21-2008 06:40 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
