#1 |
Help Needed
I am a newbie on here and a very UNhandyman. Here's what I want to do. I want to install some shut off valves under my bathroom sink as there are none. If I cut off the old connection, it would only leave about an inch of the copper pipe left. Is that enough room for a compression fitting? If not, is it possible to sweat on some sore of connection and then add more length of copper pipe? I was thinking it would LOOK like a PVC connector that is bigger than the pipes and both pipes fit into it. Only these would be of copper.
#2 |
the Musigician
Help Needed
HI and welcome to the forum.
I BELIEVE a "sharkbite" fitting will work in your case. I could be wrong though, considering you only have an inch to work with. DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Persona Non Grata
Help Needed
If you could post a pic that 'll give us a better idea of what you're dealing with.
| Display Modes | |
| Size of whole house fan needed | Doug Crf | General Discussion | 20 | 02-26-2011 12:29 AM |
| Need advice on quantity of primer and paint needed | laurat | Painting | 8 | 01-01-2011 11:53 AM |
| Combustable air, how much is needed? | Lee Roy | HVAC | 9 | 10-27-2010 11:17 PM |
| Wire Needed for GF / Arc Fault breaker | jamiedolan | Electrical | 13 | 09-20-2009 09:15 AM |
| calculating amount of exhaust vents needed | bitty071203 | HVAC | 4 | 06-09-2009 08:13 PM |
