HELP! Need Advice On Fixing Rotting Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2010, 11:53 PM   #1
HELP! need advice on fixing rotting iron pipe
Hello,
New to the forum and I needed a proper solution on how to approach this issue. While working on a wall in the kitchen I found that the ventilation pipe for the kitchen sink is rotting away. I have a two story home and I first discovered the problem on the second floor, which I was working on something that was not related to this. I had to do some work on the first floor wall and then I saw this as well:HELP! need advice on fixing rotting iron pipe-104_8833.jpg
The bigger challenge I'm finding is replacing the T joint, which is showing signs of corrosion and this is behind the kitchen counter.
padeone is offline   Reply With Quote
Old 07-01-2010, 02:53 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
All of that obviously needs to be completely replumbed.
I would go with white plastic PVC or black plastic ABS pipe, and go all the way back to good solid drain pipe connections. You can use Fernco or else no-hub connectors to transition from one material to another.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
cast iron sand pipe Cranky Bait Plumbing 2 03-19-2010 05:52 PM
Replacing a Cast Iron Waste Pipe Beylah Building & Construction 0 01-18-2010 02:42 PM
patching a cast iron pipe realbeginner920 Plumbing 4 08-26-2009 06:05 PM
How to fix a BIGGER hole in a cast iron pipe?! skatestoked2000 Plumbing 3 12-08-2008 12:12 PM
