Help... My Transition Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2009, 08:16 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Help... my transition leaks
I cut my cast iron waste pipe right after the closet bend. Transitioned over to PVC with a stainless fernco and installed the closet flange. I just poored a bucket down to test it and it leaks pretty good from the bottom of the rubber where it meets the cast pipe. Any help would be appreciated, this is the only toilet in the house.
J187 is offline   Reply With Quote
Old 07-08-2009, 08:24 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I always use a frenco without the band
Make sure the cast is cleaned up the best it can be and some times it takes a few more turns with the nit driver.
Old 07-08-2009, 08:29 PM   #3
J187's Avatar
Rewards Points: 516
I thought It was code that it must have the band? The cast is nice and clean and the clamps are tight. So it is OK to use the fitting without the band? I think that would help... there seemed to be some better fittings that didn't have the band.
Old 07-08-2009, 08:36 PM   #4
Rewards Points: 560
Don't know what ou local code is..Here no band is needed
Heck try it, are getting inspected if so talk with local code dept
Old 07-08-2009, 10:47 PM   #5
J187's Avatar
Rewards Points: 516
Hope the code checks out because I drilled out the clamps, took the band off and used the clamps on the rubber. Worked like a charm. Thanks.
Old 07-08-2009, 11:41 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Dont know about your own code, but here ferncos cannot be used above ground. The reasoning behind it is that a regular fernco has give to it and if used underground then the backfill material (sand/gravel) will keep the piping lined up. If used above ground then there's nothing to keep those pipes aligned.
Anything above ground must be a banded coupling. (Talking about the code here in Ohio. Your code may differ). In the application of transitioning from cast to pvc either a pvc to no hub adapter and a no hub coupling or a proflex (plastic X cast iron) coupling must be used. Either way the regular fernco, no hub band and the proflex are designed to be torqued to 60 inch-pounds. Even when torqued correctly however, sometimes you do get a leak. There is a product on the market that helps seal these joints. One brand is Black Swan and while messy it really does work.
Glad you got it to stop leaking. Thought I'd throw my 2 cents worth in and see if I get change.
JDC is offline   Reply With Quote
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
hardwood to tile transition navychief39 Flooring 8 03-04-2009 06:32 AM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 02:19 PM
Need some transition moulding advice... confused Flooring 4 08-24-2006 04:35 PM
