Help With My Culligan 9" Gold Water Softner - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2011, 11:49 AM   #1
Help With My Culligan 9" Gold Water softner
Hi all, I am hoping someone here could help me out with my settings set-up of my water softner. Im not sure what they should be at. I have a Culligan 9" Gold Series (metered) water softner. Salt tank is filled with Solar Salt Crystals and my water facts are in the link provided below on page 7. If someone could be so kind as to help me out that would be great! TIA
CJ.
http://www.chesterwater.com/waterqua...ccr2010web.pdf
WGFA is offline   Reply With Quote
Old 09-21-2011, 01:27 PM   #2
Water Treatment
Rewards Points: 848
Is there a problem with the system?
Is there a reason you are looking at changing the settings?
Akpsdvan is offline   Reply With Quote
Old 09-21-2011, 01:33 PM   #3
No Probllem, I bought it and installed it myself that's all.
Old 09-21-2011, 02:30 PM   #4
Water Treatment
Rewards Points: 848
It looks like the hardness is the only thing really going on..
8 grains.
Here is a link to a page that has culligan manuals.
http://www.culligan.com/en/service-a...olete-manuals/
If the unit has 1cubic foot of resin and you use 8lbs of salt each regen I would use 20000 capacity.
Old 09-21-2011, 03:28 PM   #5
8 grains.
Thanks for the info but im not sure what im looking at in the manuals. So in the menu settings under doSAGE ill put in 8lbs.? Also what u are saying is that I should put MAXCAP in the and 20000 in the "regen gallons". So what do u recommend for my hardness number? Aslo what do I select for "Iron", N? Sorry but this is all new to me and I am learning as I go.
Old 09-21-2011, 05:10 PM   #6
Water Treatment
Rewards Points: 848
Where it asks for the salt dosage put 8
Where it asks for the capacity use 20000 or 20 how ever it is logging it.
Where it asks for the comp hardness use 9
Where it asks for iron put N
We all started on the ground floor at some time.
Old 09-21-2011, 05:26 PM   #7
Thanks, I will put all this in when I get home and report back later to let you know how I made out.
CJ
Old 10-07-2011, 08:00 PM   #8
Thanks again Akp. The settings seems to be working better. Let ask you something, if I want the water to be softer what direction do I go with the hardness number? If infact that's what makes it softer. Thanks.
Old 10-08-2011, 11:16 AM   #9
Water Treatment
Rewards Points: 848
0 is as low as one can go .. but some might feel the full 0 at the start of the usage gallons but just before the unit cleans the water might be at 12ppm of hardness, while that is still soft, some might feel that little bit of hardness.
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
