Old 11-12-2008, 07:38 PM   #1
Kellster
mjkpainting's Avatar
Help/moving dryer vent
This is my first time on this so bare with me if I'm not asking in the correct place.
I am fairly handy around the house but by no means an expert especially with plumbing
I am moving a dryer vent b/c I am finishing my basement. I need to move the dryer vent. I think my best location is about 10 feet away and I need to cut through the sill plate and run the vent it outside. My thoughts were this:
Drill through ( with a long 1" bit drill bit because that's all I have) the sill plate from the basement
Go outside and locate the hole I drilled
Draw a circular template of the diameter of the vent pipe (or that pipe that attaches to the exterior part of the vent
Cut the vinyl siding with a cutting tool
From the hole I drilled attempt to cut the diameter of the vent pipe with a sawz All or reciprocating saw (or should I use a hole saw???)
Any suggestions or am I way off on this?????
Here are some pictures
Help/moving dryer vent-img_2198.jpg   Help/moving dryer vent-img_2197.jpg   Help/moving dryer vent-img_2201.jpg   Help/moving dryer vent-img_2200.jpg
mjkpainting is offline   Reply With Quote
Old 11-12-2008, 07:44 PM   #2
wait for someone more knowledgeable then me, but I'm curious if you are moving the dryer as well, adding ten more feet to the duct is asking alot. Be a whole lot of hose to keep clean of lint.
DUDE! is offline   Reply With Quote
Old 11-12-2008, 08:14 PM   #3
Kellster
Sorry- I wasn't very specific- I am moving the vent or duct 10 feet closer to the dryer. It will be actually vented right above the dryer. Thanks
Old 11-13-2008, 09:44 AM   #4
gravity always wins
Drill a 1/4" hole from the inside centered at where you want the vent. Drill the big vent hole from the outside with a hole saw. Use the 1/4 hole as a pilot.
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 11:25 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 12:31 PM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 07:50 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
