Help Me Finish Fixing My Running Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2012, 09:55 PM   #1
Rewards Points: 370
help me finish fixing my running toilet
trying to fix a toilet where the tank was constantly running. I bought the new flow valve unit that controls the water filling the tank and want to replace the whole thing since the old one broke near the bottom (brittle plastic or something)
problem is I can't figure out how to remove the plastic that is left. See picture.
can I just start breaking all the plastic and hope what's in the screw hole will break? should I try to break up the seal and go at it that way? thoughts?
any help is appreciated. figured someone here had this problem and has an answer.
Thank you!
MLMIB is offline   Reply With Quote
Old 09-04-2012, 10:01 PM   #2
Rewards Points: 582
remove big nut under tank its where water supply hooks up...may need a wrench for inside so it don't turn....remove all old stuff...
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 02:39 PM
Fixing flashing after finish coat dirtbuster Painting 2 01-29-2011 01:14 PM
Water main break yesterday - now toilet won't stop running spidrw Plumbing 2 01-10-2011 10:27 AM
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 11:07 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
