Help Me Find A Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2009, 10:01 AM   #1
liscenced electrician
Rewards Points: 538
help me find a valve
I am building a house with a tile shower that will have 3 shower heads. 2 normal shower heads on oppsoing walls, and a rain head in the center
i've heard the cheapest way to go is a 3 way 7 position diverter that will let me turn on any head, or any combination of 2, but not all 3
That sounds exactly what im looking for, but i can't find anything like that local, and online everything i see doesn't have much for a product description. Can you guys help me pick a few out that will suit my needs and find temp/volume controls that match, or are in the same finish. Im trying to get this done as cheap as possible, so id like to go chrome so i can get matching finishes easily
can anyone help me.
ps, did i mention im running out of money. So i need to go the cheapest route possible, without scabbing it together
jimmy21 is offline   Reply With Quote
Old 05-09-2009, 10:15 AM   #2
Rewards Points: 538
i don't have an exact budget for this, i will spend whatever it takes, but i've been figuring out pretty quick that with these custom showers that you get into the thousands real quick. I can just tell you i don't have that kind of a budget
will this valve do what i want, and then i just need temp/volume controls and im all set?
http://www.faucet.com/decor/product....4876&fh=Chrome
Old 05-09-2009, 08:35 PM   #3
Rewards Points: 538
anyone?
Old 05-09-2009, 10:53 PM   #4
http://www.homecenter.com/product_Am...er_211332.html
Rivethead is offline   Reply With Quote
Old 05-10-2009, 09:32 AM   #5
can anyone help me.
Here is a danze diverter :
http://www.needplumbingsupplies.com/...s.asp?id=14186
And here is the matching shower valve :
http://www.needplumbingsupplies.com/...s.asp?id=17661
Or you can go Delta.
trim for diverter :
http://www.needplumbingsupplies.com/...s.asp?id=17394
diverter rough valve :
http://www.needplumbingsupplies.com/...s.asp?id=17447
Delta trim kit for shower :
http://www.needplumbingsupplies.com/...s.asp?id=17368
Delta Rough valve for shower :
http://www.needplumbingsupplies.com/...s.asp?id=17435
plumber Jim is offline   Reply With Quote
Old 05-10-2009, 10:16 AM   #6
Since you have received many locations to obtain the parts, I hope you have figured out the supply piping size to operate this and the water heater capacity needed.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-10-2009, 11:24 AM   #7
Rewards Points: 538
Thanks for the help, i've now found many sources and many different options, exactly what i was looking for.
we ran 3/4 hot and cold to the shower and i'll just adapt to 1/2 if the valve calls for it.
. What size water heater should we put in the house? Its a about 1500 sq ft with 3 bedroom 2 bath
Old 05-10-2009, 12:37 PM   #8
Think about just the new shower. Low flow shower heads use 2-1/2 GPM and I don't know what the rain head will use. Figure just the two heads will use 5 GPM so that would take a good protion of the hot water from a 50 gallon unit for a 10 minute shower. I realize not all the water used is hot but I am also thinking about the cold water replacing the hot in the heater. This is going to affect the temp of the remaining water in the tank. You are correct with running at least a 3/4" header to the shower unit.
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Is this gas ball valve safe? nutlog Plumbing 17 12-23-2008 01:40 PM
White-Rodgers zone valve 1361 wiring ??? srauner HVAC 1 12-06-2008 11:50 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
